Results 1 to 5 of 5
02-20-2009, 02:09 PM #1New Member
- Join Date
- Oct 2008
- Posts
- 11
- Location
- Maine
- Tractor
- John Deere 870
John Deere 390 plow blade
Hi i built a quick attach for my 870 Jd to fit the 390 Jd blade on the loader it worked out great used a cushion vlv also to protect the hose and rams .The blade was new that i had purchased it at a auction . i found it had a bad plow cylinder and replaced it with a new one from Jd 390.00 does any one know of a ram to replace the JD one. it is the quick switch ram. thanks sleepy.
02-20-2009, 04:34 PM #2
Re: John Deere 390 plow blade
What was "bad" with the cylinder? You can purchase new seal kits for about $20 or so (I just rebuilt mine a few months ago)
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
02-21-2009, 12:06 AM #3New Member
- Join Date
- Oct 2008
- Posts
- 11
- Location
- Maine
- Tractor
- John Deere 870
Hi hyd oil was spraying out the vent hole when activated to extend does that have a ball check where the vent is? any info would be great thanks Sleepy.
02-21-2009, 06:20 AM #4
John Deere 4110HST
02-21-2009, 01:36 PM #5New Member
- Join Date
- Oct 2008
- Posts
- 11
- Location
- Maine
- Tractor
- John Deere 870
HI thanks for the info.Sleepy
