HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Hydraulics
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-29-2009, 08:42 PM   #11 (permalink)
Super Member
kennyd's Avatar
Default Re: JD 970 Power Beyond Plumbing...want to add valve for flail mower side slide cylin
Quote:
Originally Posted by ttkeeler View Post
The specs say 8.7 gallons per minute of flow. I don't know how many 'spools' I need. Does that have anything to do with how many directions or cylinders are being controlled?
One "spool" operates one DA (dual acting) cylinder, like your FEL valve is a two spool valve. I should have asked "How many cylinders will you be needing to operate at once?"
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is offline   Reply With Quote
Old 06-29-2009, 09:56 PM   #12 (permalink)
Quote:
In the case of the FEL there are cylinders on each side so wouldn't one spool be working two cylinders at a time for the raise and lower and two for the curl/dump? I suppose a two spool valve, like my FEL has would be handy in case I wanted to add a cylinder to the three point for the box scraper or blade. The forward and back could be used for raise and lower and the left and right for the flail shift cylinder. I would guess that is a pretty spendy valve however and a two spool valve with two handles would be much less expensi ve. Any other important tips on valves other than open center with at least 1/2" ports?
__________________
JD 970 w/ 440 Front Loader, 60" Rears Flail Mower, 48" DR Grader, 66" Box Scraper, 72" Rear Blade, Front & Rear Pallet Forks, 8B Backhoe
ttkeeler is offline   Reply With Quote
Old 06-29-2009, 10:09 PM   #13 (permalink)
Super Member
kennyd's Avatar
Those cylinders are in "parallel", so the valve see's them as one cylinder.
Here are two valves I would recommend for you:
Joystick Valve
Two Handled Valve
So for $50 you can get the joystick if you want it. The main thing is to meet or exceed the GPM requirement for your machine...so a 10 GPM rated valve is a good fit.
__________________
JD 4110HST
JD 4x2 Turf Gator
Old 07-03-2009, 01:05 AM   #14 (permalink)
Joystick Valve
Two Handled Valve
I ordered the Joystick Valve and should have it tomorrow. Next task will be picking a mounting location then finding the hoses and fittings...hopefully I can find them locally. 1/4" hoses will probably suffice for what I will be using for cylinder(s) in the rear with 1/2" lines for the 'In' & 'Out' to the valve.
__________________
Old 07-04-2009, 12:47 PM   #15 (permalink)
Joystick Valve
Two Handled Valve
I got the valve and have selected a location for mounting. Now connecting to the Power Beyond...the Inlet to the valve from the Power Beyond is pretty obvious but I end up with two return lines so which one do I connect to the outlet or return on my joystick? Do I use the 3/8" male quick connect that was removed from the supply quick connect or the pipe plumbed 1/2" male quick connect into the rockshaft? Hopefully this makes sense to anyone that has seen a Power Beyond on a JD970. Do they use both 3/8" and 1/2" quick connects so it cant be connected wrong or does the return need to be 1/2"? Without going and looking I believe they are both 1/2" hoses.
I assume that like with the BH I would use the 1/2" male quick connect at the rocker shaft for the return and just leave the 3/8" male quick connect unconnected?
__________________
Old 07-04-2009, 01:57 PM   #16 (permalink)
After further looking I dont see why I can't just use the 3/8" male quick connect (removed from the PB 3/8" FM quick connect) for the return and just use the 1/2" male quick connect for the Backhoe return, it appears that they both end up in the same place. Am I wrong or correct?
__________________
Old 07-04-2009, 05:24 PM   #17 (permalink)
Super Member
kennyd's Avatar
I am getting confused...why do you have 2 return lines? Can you post a picture?
__________________
JD 4110HST
JD 4x2 Turf Gator
Old 07-04-2009, 06:24 PM   #18 (permalink)
Here are some pictures...maybe one of them is not a return line?
2nd picture shows the 1/2" quick connect that the hose from BH connects to, only used with the BH otherwise it has a dust cap on it. The other pictures show the 'loop' hose...the FM 3/8" QC on the left connects to the BH, the Male 3/8" QC that is left doesn't hook to anything with the BH connected. 4th picture shows 3/8" QC disconnected and ready for BH>
jd-970-power-beyond-plumbing-dsc_2351-640x480-.jpg  jd-970-power-beyond-plumbing-dsc_2353-640x480-.jpg  jd-970-power-beyond-plumbing-dsc_2354-640x480-.jpg  jd-970-power-beyond-plumbing-dsc_2355-640x480-.jpg
__________________
Old 07-05-2009, 09:58 AM   #19 (permalink)
Super Member
kennyd's Avatar
OK, pictures worth a thousand words
You do NOT need the other return for the backhoe-it bypasses the 3PH so it's inactive when the BH is mounted.
You only need to plumb the new valve between the "loop" hose and 3/8" QD's.
__________________
JD 4110HST
JD 4x2 Turf Gator
Old 07-05-2009, 12:51 PM   #20 (permalink)
Ok sounds good. So as long as a person continued to use 'Open Center' type valves you could add more into this same loop right? That could come in handy if I wanted to put a hydraulic cylinder on the backhoe thumb someday.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.25124 seconds with 9 queries
