like anormel singel spool valve but the handle also moves side to side to opperat a second spool
If you describe the application maybe we can give other options...no a joystick will not work for my aplacation
My Case 580CK FEL control is one handle two valves. Forward and backward on handle will lower and raise the loader, and left to right on the handle will tilt the bucket forward or backward respectively. It is however what would still consider a joy stick although not the same as what a search of joy stick valves would yield now days. Your diagram though appears you wish to control a function with a twisting motion. I do not believe this would possible unless you went with electric solenoid valves and then you might have a time locating the proper switches but it is possible. Anyway I will post a pic of my case set up when I can, in case that might work for you.
Wayne
