HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Hydraulics
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-08-2009, 07:13 AM   #11 (permalink)
Super Member
kennyd's Avatar
Default Re: Converting Top Link To Hydraulic
Quote:
Originally Posted by jinman View Post
Vic, if you can find a 1/2" diameter rope, take a 36" piece and make a loop. You need the loop for the hoses minimum bend radius. Place the looped hose in the approximate position of the new toplink and see what you think. I think 36" is the perfect size for the least stress on the hose. Also, I think you will find that you have plenty of room for your hoses to come out the top of the DPOCV. If you put it to the side, it may interfere with additional QDs you could add later. Up is best in my opinion. I'll try to find picture that demonstrates this tomorrow.
An old piece of garden hose will work better than rope. I agree that the 36" length is probably good.
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is offline   Reply With Quote
Old 09-08-2009, 10:52 AM   #12 (permalink)
Super Star Member
jinman's Avatar
Quote:
Yessir! That's a fact.
I found the photo I was looking for. It shows a much better view of the area around the remotes. Our remotes are located very close to the toplink adapter on the tractor and a side-mounted DPOCV would stick out in the way of the hose attachments on the right side. I suppose you could rotate it to the left side, but I think the arrangement in the photo is fine and assures the hoses are up and away from most obstructions. The rigid hydraulic tubing also makes a good place to loop the HTL hanger to hold it up when not needed.
__________________
Jim
jinman is offline   Reply With Quote
Old 09-08-2009, 11:11 AM   #13 (permalink)
Gold Member
brandoro's Avatar
Jinman, what is that clamp looking thing on your top link ram? Is it a gage so you can return to a certain setting or does it have another purpose??
__________________
Rod.
B3030HSDC, LA403 FEL, Landpride-BH, RFM, tiller, FM2060 flail,BX42 chipper, Farm King 3pt snowblower, PTO generator, homebuilt splitter, counterweight and 3pt carry all.
brandoro is offline   Reply With Quote
Old 09-08-2009, 11:43 AM   #14 (permalink)
New Member
ALso thanks to Jinman's advice an inline restrictor was necessary for mine.
geblackwell is offline   Reply With Quote
Old 09-08-2009, 04:18 PM   #15 (permalink)
Super Star Member
jinman's Avatar
Quote:
Yes, it used to have a sliding graduated gage on the side, but I never used it. It took a lot of abuse one time while I was backing into the brush with my rotary cutter. I removed the rod, but never removed the clamp. It just slides up and down the ram. I've thought dozens of times that I should remove it, but I never think of it when I have an allen wrench set handy.
GEBlackwell: Can you see two restrictors in my last photo? They are in the top hose on the top QD on both sides of the HTL. They take up very little space, but give you a lot of control.
__________________
Jim
Old 09-08-2009, 07:11 PM   #16 (permalink)
kozak's Avatar
kennyd & jinman,
Thanks....I'll go with your recommendation of 36" hoses.
Jinman, the photo you attached, looks like you have adapters that get connected into the quick attach remotes. How do I determine what size my QA remote connections are. I think you indicated 1/2" in an earlier post. I checked the ID of the outlet port of the remotes & it looks like 7/8". Is that what size the port should be for a 1/2" QA connection ??
Thanks,
Vic
__________________
NH TC35D SS, c/w FEL & Universal Forks. AGCO Allis 1614 with MMM.
kozak is offline   Reply With Quote
Old 09-09-2009, 02:56 AM   #17 (permalink)
New Member
jinman did you get the line restrictors from CCM? I just added an HTL to my TC45DA with one, soon to be 3 rear remotes, and definately need to slow the cylinder travel down.
mytc45da is offline   Reply With Quote
Old 09-09-2009, 09:02 AM   #18 (permalink)
J_J
Super Member
J_J's Avatar
Quote:
Originally Posted by kozak View Post
kennyd & jinman,
Thanks,
Vic
Instead of using 1/2 hose, why not use 1/4 hose and that will slow down the GPM to the cyl, and if that is not slow enough, there are fittings that have an R in the part number that means restricted. The 1/4 hose and QD's will cost less, and do the same job.
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is offline   Reply With Quote
Old 09-09-2009, 10:06 AM   #19 (permalink)
Super Star Member
jinman's Avatar
Vic, 1/2" is the inside diameter of the connection or the ID inside a hose. When you measured the 1/2" QD, you measured the opening of the female adapter which equals the OD of the male adapter that will be attached to the hose.
JJ: The QD adapters (female) that come on New Hollands remote kit are 1/2" adapters. Therefore, you have to use a 1/2" to 1/4" adapter to get the 1/4" hose connected to the 1/2" QD. We have been suggesting 1/4" hose as you have. It's just that the tractor QD connectors will be 1/2".
Mytc45da: I got my restrictors from my NH dealer. He had them in a self-service parts bins with other hydraulic hose and plumbing components. It was not obvious what they were without knowing what you are looking for. I'd ask my tractor dealer or go to a hydraulic shop in your area. Mine were less than $5 each and have a 0.030" opening. They are especially useful for the HTL, tilt cylinder, and FEL grapple circuit.
__________________
Jim
Old 09-09-2009, 01:42 PM   #20 (permalink)
J_J
Super Member
J_J's Avatar
Understood. If you want real precision, in lowering the 3pt implements, a needle valve in the circuit will let you go from full flow of the hose, to a gradual drop down. You set it for what ever function you are using. The washer restricters will work, but you have to figure out which one you need. Some of the fittings have with built in restricters.
__________________
J.J.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.31037 seconds with 9 queries
