HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Hydraulics
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-12-2009, 10:27 AM   #21 (permalink)
kozak's Avatar
Default Re: Converting Top Link To Hydraulic
Well.....I was hoping I could communicate back by now that I had ordered the HTL c/w hoses & QD's. Unfortunately, CCM will not ship to Canada.
They will ship to a US border address & then I have to pick it up. That's probably what I will end up doing. I did check out a few other companies that supply HTL's but they just don't have the same info or the same selection.
Vic
__________________
NH TC35D SS, c/w FEL & Universal Forks. AGCO Allis 1614 with MMM.
kozak is offline   Reply With Quote
Old 09-12-2009, 11:34 AM   #22 (permalink)
Super Member
kennyd's Avatar
Vic
Surplus Center ships to Canada don't they? They have the same HTL as CCM now.
Look HERE.
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is online now   Reply With Quote
Old 09-12-2009, 11:46 AM   #23 (permalink)
New Member
I just got a hydraulic top link for my john deere and I got it from Dalton Bearing and Hydraulic out of Tennesse. Its a cat 2 toplink made by Prince with a 3in bore and 10in stroke. It is a super heavy top link, I got it yesterday and had a couple hoses made and put it on then I had to try it out. It works great. They also have a cat 1 top link available as wellthats cheaper than the ccm you all are talking about, just thought I would let you know. Later...... Bullsram
__________________
08 JD 5103 FWA, 553 Loader w/72in bucket
Frontier RB2196H
Frontier RC1072
Frontier Pallet Forks
Home made carryall
JD 2-14 plow
07 JD X540 26hp 54in
07 Dodge 3500 drw ,45 gal Auxiliary tank, B/W hitch
07 Yamaha Grizzly 700 EPS, Warn winch & bumper
88 Starlite 20' GN 14k GVw
Alot of other stuff
bullsram is offline   Reply With Quote
Old 09-12-2009, 12:34 PM   #24 (permalink)
MtnViewRanch's Avatar
There are several hydraulic top links out now, with and without the check valve. You just have to look. CCM is not the only supplier of top links with the check valve.
__________________
Brian
MtnViewRanch is offline   Reply With Quote
Old 09-12-2009, 01:24 PM   #25 (permalink)
Gold Member
I purchased my toplink from CCM with check valve a few years back. I use it ALL the time on the box blade- couldn't live without it! It's been working perfectly without any trouble. Two thumbs up for CCM!
- JC
__________________
Mahindra 3510 FEL, 72" BB, 84" RFM, 66" Tiller, Ford 8N '58 w/FEL + Sherman BH 4sale; MF TO20 4sale; '58 Cletrac OC-2 4sale
DiskDoctr is offline   Reply With Quote
Old 09-12-2009, 06:15 PM   #26 (permalink)
kozak's Avatar
Thanks for the info guys. I will look into some of these other sources Monday.
Thanks Again,
Vic
__________________
Old 09-14-2009, 10:18 AM   #27 (permalink)
New Member
Machold's Avatar
Kozak, please keep us informed... My local K dealer is going to install everything for me; they say they make the Hydraulic unit "in house". A bit far from you, however, Ben Berg in Wainfleet.
Machold is offline   Reply With Quote
Old 09-14-2009, 08:30 PM   #28 (permalink)
kozak's Avatar
H e l l o MacHold in Niagara Area,
Checked out the Ben Berg Equipment Web Site tonight. Will call them tomorrow morning & see how long & how much for a HTL. Much easier if I can deal with somebody in Ontario.
Thanks for the Source,
Vic
__________________
Old 10-06-2009, 09:43 PM   #29 (permalink)
kozak's Avatar
Quote:
Well, it was a little disconcerting at first but all's well that ends well. Ended up getting the cylinder from Ben Berg Equipment in Wainfleet Ontario. Actually, my hat's off to this Dealership. They came through when things did'nt quite work out the first time. For anybody in Eastern or Central Canada, contact Dave in Service at Ben Berg & he will take good care of you. (1-905-899-3405)
Have worked the cylinder with the forks on the back (approx 400 Lbs) & cylinder moves smoothly. No leaks. Had restrictors put in. (This is a must, otherwise speed is far too quick) Now for the REAL test once it stops raining up here. Still have some heavy landscaping rock to move.
Here's a pic of the final installation. Does not look as good as others I have seen but then most of those had the lock-up valve which then provided connections vertically up & close together in the same orientation which gave a neater appearance. With my set-up, probably would have been better to have slightly smaller hose lengths. But I'm not complaining, better too long than too short & the thing works marvelous.....
Thought I would add a pic of the Beast just for good measure !!
Hey MacHold, did you ever get your hydraulic cylinder(s) installed ??
Ariva-Derchie,
Vic
converting-top-link-hydraulic-cylinder_1.jpg  converting-top-link-hydraulic-tractor_1.jpg
__________________
Old 10-06-2009, 09:51 PM   #30 (permalink)
Super Member
kennyd's Avatar
A couple zip ties to hold the hoses together would make it look very clean...
__________________
JD 4110HST
JD 4x2 Turf Gator
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.23066 seconds with 9 queries
