HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Hydraulics
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-06-2009, 05:55 PM   #1 (permalink)
kozak's Avatar
Default Converting Top Link To Hydraulic
Hi all,
When I purchased my Tractor, I had Dealership install a pair of remotes. The remotes are plumbed to some sort of valve that is controlled by a lever that was added.
From all the threads I have reviewed on this topic, it would seem all I have to do is replace the mechanical top link with a hydraulic cylinder from CCM & then just connect the ports via two hoses to the pair of remotes & I'm done. Is it really that simple since I already have the remotes ??
Thanks For Any Input,
Vic
converting-top-link-hydraulic-remotes_1.jpg  converting-top-link-hydraulic-remotes_2.jpg
__________________
NH TC35D SS, c/w FEL & Universal Forks. AGCO Allis 1614 with MMM.
kozak is offline   Reply With Quote
Old 09-06-2009, 07:02 PM   #2 (permalink)
MtnViewRanch's Avatar
Default Re: Converting Top Link To Hydraulic
Vic, yes it is that simple. Measure your existing top link to get your shortest and longest lengths. As long as you are happy with those lengths, then get the closest top link that will match. If you need it to be shorter or longer for some of your implements, then you may need to take that into consideration when purchasing your top link.
Good luck
__________________
Brian
MtnViewRanch is online now   Reply With Quote
Old 09-06-2009, 09:07 PM   #3 (permalink)
Epic Contributor
Bird's Avatar
Send a message via ICQ to Bird
Yep, like Brian said, it's really that simple.
__________________
Bird is offline   Reply With Quote
Old 09-07-2009, 09:30 AM   #4 (permalink)
Super Star Member
jinman's Avatar
Vic, you will not only need to know the proper length of the toplink, but also the size of hoses and length. Mark at CCM will make hoses for you and include the proper sized adapters to go to your 1/2" QDs (if you order the hose kit--recommended). I would suggest 1/4" hoses at 36" long. That way you can make a stress relief loop and attach the hoses to your HTL. Be sure and run the 3PH up and down to make sure everything clears. Your tractor has a hanger for the toplink when it is not in use. Make sure this hanger will not snag your HTL hoses. I just push mine out of the way to the left. When I disconnect the HTL and don't want it hanging down, I pull the hanger back out and hook the hoses to hold it up out of the way.
Here is a picture of my connections.
Oh yes. . .the other thing you have to decide is which way to attach the hydraulic hoses. Do you want the HTL to extend when you move the remote lever toward the rear of the tractor and retract when you push it forward? Swap your hoses in the remote QDs until you get it working the way you are most comfortable with.
__________________
Jim
jinman is offline   Reply With Quote
Old 09-07-2009, 12:36 PM   #5 (permalink)
Gold Member
I just added a ccm toplink and ordered the hoses from them as well. The only issue I had was leaking hydraulic fluid at the hose/toplink connection. I tried a number of liquid sealants and eventually carefully used teflon tape which stopped the leak. In general, avoiding teflon tape in a hydraulic system is best, you don't want bits of tape getting into the system so you must be careful. Otherwise, since you all ready have remotes, install is simple. Be careful that it doesn't bind or hit anything when you install it- I removed the old top link hanger and some have had to remove the PTO saftey cover as well.
anojones is offline   Reply With Quote
Old 09-07-2009, 01:02 PM   #6 (permalink)
kozak's Avatar
MOST Excellent.....thanks for the great info. I was always wondering what that hanger was for
Jinman, do you really think I need 36" hoses given the proximity of my remotes to the top link ??
Vic
__________________
Old 09-07-2009, 01:14 PM   #7 (permalink)
I have a few questions for you guys. Those of you that have CCM top links, would it be better to have the DPOCV at one end vs the other end? So does it work out to have it like in Jim's picture, or would it be better to have it out closer to the ram? I see most top links have the outlets straight up, when I made my "TnT" I put the fittings to the side, and that has worked well for me. One last thing, I have adapted my stock top link hangers to hold my hydraulic top links, has anybody else done the same?
Thanks for any responses, but not really any big deal, just wondering.
__________________
Brian
Old 09-07-2009, 01:55 PM   #8 (permalink)
Charlesaf3's Avatar
Location: Boston & Martha's Vineyard, People's Republik of Massachusetts
I had CCM do mine with the dpocv on the side - b3030 is really tight, and top hits into the back of the sheet metal
__________________
Charles
Kubota B3030
Kubota M59 w/hydro thumb
Neat stuff - ATI Preseeder, Hydraulic PHD, Wallenstein BX62r Chipper, Millonzi Grapple, CA 4n1 Bucket. Delta Hook Rear QA system.
Too many other random attachments to list (or to own, per my gf) and a really bad tool addiction. But at least I haven't bought a dump truck or bulldozer. Yet.
Charlesaf3 is offline   Reply With Quote
Old 09-07-2009, 03:02 PM   #9 (permalink)
Quote:
I was thinking that on the smaller tractors it would be better on the side.
Charles, did you ever get your side link for the 3030?
__________________
Brian
Old 09-08-2009, 12:01 AM   #10 (permalink)
Super Star Member
jinman's Avatar
Vic
Vic, if you can find a 1/2" diameter rope, take a 36" piece and make a loop. You need the loop for the hoses minimum bend radius. Place the looped hose in the approximate position of the new toplink and see what you think. I think 36" is the perfect size for the least stress on the hose. Also, I think you will find that you have plenty of room for your hoses to come out the top of the DPOCV. If you put it to the side, it may interfere with additional QDs you could add later. Up is best in my opinion. I'll try to find picture that demonstrates this tomorrow.
__________________
Jim
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.41643 seconds with 9 queries
