HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Hydraulics
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-26-2009, 05:03 PM   #11 (permalink)
J_J
Super Member
J_J's Avatar
Default Re: Extending Cylinder when off tractor???
Just take the rod end loose and extend or set it to whatever position using the hydraulics. Then take off the hoses, plug them, and drain the cylinder. Done deal.
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is online now   Reply With Quote
Old 10-12-2009, 02:40 PM   #12 (permalink)
Gold Member
CHDinCT's Avatar
Well, all the welding work is done and I went to hook up my new cylinder for hydraulic angling and had an issue that's got me a little stumped. When I hooked up the cylinder to my quick connects, I could get it to extend about half way and then retract a few inches. After that it would only move an inch or two in or out before going into relief. I did double check the quick connects and also tried the other FEL circuit to no avail. Could it be air bound?
I've hooked up other new cylinders in the past and it took a few cycles to get it moving smoothly in and out, but this one just does not seem to want to move without binding. What's weird is that when we had it hooked up to the plow with the ports open, we could move the cylinder in and out by manually angling the plow. Seemed to move fine then. Looking for any help in what could be wrong.
Oh, I was going to take the hoses off and fill it with oil and try again, but I'm out of hydraulic oil right now. Should have some more in a few days.
Here's a few pic's of the mounts for the angle cylinder
extending-cylinder-when-off-tractor-bx-front-blade-010.jpg  extending-cylinder-when-off-tractor-bx-front-blade-011.jpg
__________________
Chris
2 acres and a mule, err, Kubota
BX1860, FEL, 54"MMM, 5' FF Rake, DR PTO Chipper, 5' Woods RB, Powerhorse 3PH Splitter, 54" Front Blade
520-H Wheel Horse, 48" MMM, tiller, vac bagger
Cyclone Rake, and more goodies.
CHDinCT is offline   Reply With Quote
Old 10-12-2009, 02:59 PM   #13 (permalink)
J_J
Super Member
J_J's Avatar
One of the QD might be stuck, not allowing fluid to flow. Reverse the QD's on the cylinder and see if anything is different.
__________________
J.J.
Old 10-12-2009, 04:08 PM   #14 (permalink)
Gold Member
CHDinCT's Avatar
JJ thanks but I did check the QC's and thought I tried both circuits, BUT ..... you got me thinking and I just went out and traced my FEL circuits so I know for sure which QC does what function. Well, I had them completely wrong such that when I had the cylinder connected, I had one hose on a boom circuit and one on a curl circuit, then vice versa. So, I'm thinking there was no way for the fluid to come back to the valve as I tried each throw of the joy stick, thus little to no movement of the cylinder. I will try hooking it up correctly as soon as I can and see what happens. Should never have assumed which QC was for what function. Doh !!
__________________
Chris
Old 10-12-2009, 04:57 PM   #15 (permalink)
J_J
Super Member
J_J's Avatar
I had thought about that, but I figured no one would do that. I should have stated all the mis-configurations that I could think of. Glad you got it all figured out.
__________________
J.J.
Old 10-12-2009, 05:58 PM   #16 (permalink)
Gold Member
CHDinCT's Avatar
Quote:
Put the hoses back on and hooked 'er up right this time and smooth sailing. Feel a bit stupid but I just assumed the two QC for each circuit would be next to each other. Mine are configured with the 4 QC's in a row and the outer two are one circuit and the inner two the other. Who'd a thunk.
__________________
Chris
Old 11-06-2009, 01:25 PM   #17 (permalink)
Gold Member
CHDinCT's Avatar
Just to finish this thread off, here's a link to the final pic's I posted in the Kubota forum for anyone interested.
http://www.tractorbynet.com/forums/k...ml#post1784152
__________________
Chris
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.21007 seconds with 9 queries
