I understand that the 13xxx squared + 25xxx squared = 28xxx squared. If you use the sin formula or this one.
What is puzzling me is that a cylinder that has a max force of 28000lbs, can create a vertical force of 13000lbs and a horizontal force (trying to push the bed straight back against the pivots) of 25000lbs. I dont understand how the two resulting forces can add up to more than the supplied force.
The 30" side of the triangle is the horizontal force, and 16" is the vertical load. I used 16/46 as the ratio of vertical force to to the total force.
I know that the sin formula works and that I will actually have 13000lbs lift because it has probabally been tested in many situations, but I was wondering mathematically just how exactally it works out. Call me an idiot.
