chicken991
Member
- Joined
- Oct 31, 2008
- Messages
- 32
I am repairing cylinder on fel . It is an allied loader. Have seal kit on hand. My question is how do you replace the U-cup in the head plate. Any help appreciated.
I apologize for highjacking this thread, but it kind of goes along the general theme.
Where is a good site to order individual parts to rebuild cylinder? I have one on a treatment table that the local shop can not get right. They know best and will not listen to the customer. First time it was repacked I was in the shop watching as they tore it down. The rod seal end has a snap ring, then a steel ring, and had 4 identical u-cups. When they put it back together with the 4 cups they could not get the rod in so took one cup out and put a white nylon half height spacer in, it wept oil but I made do with it. Had it repacked last year and in spite of me distinctly telling them about the 4 cups they only put 3 plus the white ring and it leaks worse plus it does not hold a load at all and leaks down internally at an observable rate. I use this table every day I am in my office so I will have to take it off, open, measure, visually match, then reassemble to limp along until parts come in and it can be fixed. I just need a source for that kind of help for parts so if anyone has a favorite recommendation I surely would appreciate a heads up.
Like Top said-just pick-pry the old one out...then I boil the new ones in water to soften them up before folding into the C shape to get them in there.
i did like you said and it was a snap, i was afraid it would break the seal to fold it that much. thanks
