This post would surely have been best to post in the NH Owning/Operating forum where more NH interested folks are likely to see it. However, since it's posted here, I'll try to do my best to help. Welcome to
TBN. We hope your first post will not be your last. It's a good group here.
You said your diverter valve was working properly. When you set it to the 2 o'clock position, does the
FEL quit working? With the
FEL not working, does the
3PH still not function?
With the diverter rotated back CCW to the 10 o'clock position, fluid is supplied first to the
FEL. If the
FEL is not operating, fluid flows next to any rear remotes you might have before going to the
3PH. Do you possibly have a rear remote with it's lever stuck and not returning to neutral? If your
FEL works and you don't have any rear remote valves or a power beyond setup for a backhoe, then you should have pressure to the
3PH.
Where did you check the
3PH for pressure? Did you open the banjo fitting to see there was no pressure? Did you check the line where it comes out of the diverter valve? If you have no remote valves, you can remove the blanking plate to see if you have flow there, but it will be rather messy and you'll need to keep up with your o-rings. I suppose you could have a leak in an o-ring inside the blanking plate that could cause fluid to bypass the
3PH.
To access all this, the easiest way is to remove the right rear tire and then the support plate for the levers so you are looking at things right out in the open. You may have already done all this and know these things, but I'm just saying them to be sure.
The hydraulic system on the TC40 is pretty straight forward, so this should be easy to isolate. If you don't have pressure getting to the
3PH there is no need to open up and go inside the rear cover. It sounds to me like something is leaking and pressure is never getting to the
3PH based on your post.
