HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Hydraulics
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-02-2009, 12:11 AM   #1 (permalink)
Default BX25 hydraulic top link
The stock threaded top link on my BX25 travels from approx. 14" to 22"
I have been looking at some of the products mentioned here on TBN but have not found an exact match in a hydraulic top link.
Surplus Center has one 18.125" to 26.375" https://www.surpluscenter.com/item.a...name=hydraulic
CCM shows 14" to 18" for Kubota BX, but they also show a 16" to 22.5" which seems a better compromise. Tractor Hydraulic toplinks, Top-N-Tilt, Side link cylinders
Is there one out there that is 14" to 22" just like the stock link?
I do see that Surplus Center has some that are closer in length if you search for "swivel eye" cylinders instead of "top links" but they don't have the check valve.
If you are settling for a compromise, what retracted-extended lengths are you other BX owners using?
Jeff H is offline   Reply With Quote
Old 11-02-2009, 08:41 AM   #2 (permalink)
J_J
Super Member
J_J's Avatar
Default Re: BX25 hydraulic top link
I believe the threaded rod top link is actually longer than you really need. So a hyd top link would raise the implement a certain amount, or push down a certain distance. Which mode is more critical to you, lifting or down pressure? Try adjusting the threaded rod and see what range you need for all your implements. Measure the distance the 3pt pulls back or lowers, and that should be close, unless you just want more.
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is online now   Reply With Quote
Old 11-02-2009, 09:30 AM   #3 (permalink)
radioman's Avatar
whats the check valve for and why can't the swivel eyes be used ?
radioman is offline   Reply With Quote
Old 11-02-2009, 09:45 AM   #4 (permalink)
J_J
Super Member
J_J's Avatar
The check valve is so the cylinders do not leak down after setting to a set position. Swivel eyes are normally used. The ones on Surplus Hyd do not have the check valve. The check valve add to the cost of the cylinder. You could put an external check on then if necessary.
__________________
J.J.
Old 11-02-2009, 10:09 AM   #5 (permalink)
Super Star Member
jinman's Avatar
Jeff, I think you'd be happier with the 14 to 18 HTL from CCM. I don't own a BX, but I did use a HTL on my tractor that was 2" longer than the OEM toplink and it would not let me set my scarifiers down on my boxblade. I think having the minimum dimension is much more important than the maximum. What I would do is to adjust your manual toplink to the 14" dimension and look at it. Then, adjust it to 18" and look at it again. If that fits your needs, go with the CCM.
For all kinds of reasons that have be hashed and rehashed here on TBN, I'd surely recommend the CCM toplink or the Surplus Center toplink with the DPOCVs. I've had both and would not have another toplink without the check valves. Also, use 1/4" hoses. You don't need a lot of flow for a HTL. The 1/4" hoses will be easy to route and manage.
__________________
Jim
jinman is online now   Reply With Quote
Old 11-02-2009, 03:56 PM   #6 (permalink)
Thank you all for your input. I am new to being a tractor owner. I am surprised that the after market accessories industry for tractors is not more accommodating.
If this were the 4x4 trucks, diesel trucks, motorcycles, antique cars hobby, etc, someone would surely capitalize on the chance to make an exact fit (14" to 22") part for a popular make (Kubota BX series).
Old 11-03-2009, 10:59 AM   #7 (permalink)
Gold Member
Here's the link I built. I bought the cylinder (2.5"x8"), pilot check valve & hoses from Surplus Center. The cylinder originally had clevis ends, I bought 2 weld-on swivel eye ends from Tractor Supply and cut them off by hand with a hacksaw. I was able to get the exact length I needed this way to fit my tractor's needs. Borrowed a friend's welder and installed the swivel ends. This rig has worked well for about 5 years for me so far and it has taken quite a bit of heavy work. I've got less than $180 in the whole thing, fittings and all.
For most of my uses, the ability to go shorter is more important than going longer, especially for the boxblade and bushog and transporting the finish mower. I used my boxblade as the guide when figuring the length I needed and it worked well for everything else. For my 2 bottom plow I have to use a very long top link and it's the only implement I can't use my cylinder with and have a dedicated mechanical link set for it.
bx25-hydraulic-top-link-dscn1236.jpg  bx25-hydraulic-top-link-dscn1218.jpg  bx25-hydraulic-top-link-dscn1221.jpg
__________________
Mahindra 4110, FEL w/5' & 6' QA buckets & forks, 6' Atlas boxblade, 6' Howse rotary, Leinbach PHD w/9" & 12", 1 bottom plow, MF 2/3 bottom plow, 20"x6' bog disc,TSC subsoiler, TSC middlebuster, 6 ton Anderson 12' dump trailer, 20' Hurst 14k flat trailer.
skipmarcy is offline   Reply With Quote
Old 11-03-2009, 11:33 AM   #8 (permalink)
radioman's Avatar
I checked the surplus version- you are right, the one with a check valve looks like the right size, but it's too long for the BX. Surplus doesnt sell one seperately just like the one in the picture! SO my question is can you can the one from surplus center 1.5X8X1 DA HYD CYL SWIVEL EYES and add the small professional looking check valve from another site to it? it would be a better fit.
Old 11-03-2009, 02:10 PM   #9 (permalink)
J_J
Super Member
J_J's Avatar
Yes. you could put a pilot operated check valve on the cylinder but they ain't cheap. You could also add a needle valve to close off the fluid at the set position.
__________________
J.J.
Old 11-05-2009, 02:39 PM   #10 (permalink)
Gold Member
CHDinCT's Avatar
I added an HTL to my BX last Spring. I read various post here about the shorter lenght of the top link being more important than the fully extended length and decided to go with a SC swivel eye 13"-19" cylinder. This was the closest I could find to the stock 14"-22" top link. Unlike most, however, I wish I had gone longer, but this could be implement dependent. I have a relatively short, older Woods rear blade that when the 3PH is fully down, won't touch the ground unless the HTL is about 2/3rds extended. Similar for my rake, but not as bad. If I had a longer HTL, I could set both at a more aggressive angle. My el cheapo solution was to drill another set of holes in the lower 3PH links about 1.5" closer to the tractor. This allows the ends of the lower links to drop closer to the ground.
I don't think I would have been happy with the lenght of the CCM 14"-18" cylinder so I"m glad I didn't spend the extra for it.
I will say that my HTL with no check valves does leak down if I have an implement up off the ground for any lenght of time. Check valves would be nice, but for my uses, I couldn't justify the extra cost.
Good luck with your decision.
Oh, one other thing. If you get the SC swivel eye cylinder, watch out for the cylinder port nearer the tractor contacting your top link bracket. I mounted mine with the ports facing up and when I raised the hitch all the way up, the 90* elbow hit the top link bracket and got sheared right off. I now have the ports facing down to avoid this happening again.
__________________
Chris
2 acres and a mule, err, Kubota
BX1860, FEL, 54"MMM, 5' FF Rake, DR PTO Chipper, 5' Woods RB, Powerhorse 3PH Splitter, 54" Front Blade
520-H Wheel Horse, 48" MMM, tiller, vac bagger
Cyclone Rake, and more goodies.
CHDinCT is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.21827 seconds with 9 queries
