HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Hydraulics
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-05-2009, 07:53 PM   #11 (permalink)
Member
Default Re: adding a 3rd function valve to a 755 john deere HELP!
scotty thanks but that is the only (PIN) product identification number i found was a plate above the hitch / below the pump on the back of the tractor is there some where else i should be looking Scott ???? I can go look if some one tells me now, that im home.
Kevin M is offline   Reply With Quote
Old 11-05-2009, 07:58 PM   #12 (permalink)
Member
Exclamation Re: adding a 3rd function valve to a 755 john deere HELP!
Kenny D looking for one or two spools , should just go for two while im at it !
Old 11-05-2009, 08:04 PM   #13 (permalink)
Member
just saw something in owners manual , maybe there is another serial # i missed ! Going to look now
Old 11-05-2009, 08:41 PM   #14 (permalink)
Member
Question Re: adding a 3rd function valve to a 755 john deere HELP!
I only could find one plate on the tractor , it is under the PTO shaft , it has a bar code and the PIN# i mentioned before, the owners manual has a 6 digit serial # that covers 100001- ?? Im guessing mine is # 180465 which is part of the PIN #
Old 11-05-2009, 08:54 PM   #15 (permalink)
Super Member
kennyd's Avatar
Quote:
OK, Just did more research in JDParts (you are registered right?) It is not the S/N number I need like I thought-but rather the "transaxle S/N", here is what is says:
Quote:
TRANSAXLE SERIAL NUMBER IS STAMPED ON TOP OF THE CASE, BELOW LEFT SIDE ROCKSHAFT ARM
It should begin with 82......
The reason is they list two different kits, the older one is the picture I posted above and I think you need that big part #4 and possibly the line #16
The new kit (pictured below) just needs the diverter plug #15 and the fittings and hose that you can source locally from any hydraulic shop or online.
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is online now   Reply With Quote
Old 11-05-2009, 09:01 PM   #16 (permalink)
Super Member
kennyd's Avatar
Do you happen to know what the rated GPM is for your machine?
Here are some valve choices:
9-7695
9-7692
9-7694
__________________
JD 4110HST
JD 4x2 Turf Gator
Old 11-05-2009, 09:11 PM   #17 (permalink)
Member
Talking Re: adding a 3rd function valve to a 755 john deere HELP!
Going back out to look , stay tuned
Old 11-05-2009, 09:30 PM   #18 (permalink)
Member
I believe i have a later tractor , unsure of year ? The # i found was between the hydraulic return to the tank/ pump and the rock arm, you ment part of upper 3pth pivot i think THE# ( 843575 )
Old 11-05-2009, 09:39 PM   #19 (permalink)
Member
Found this in owners manual- hydraulic 5.6 gpm , working pressure 2050psi
Old 11-05-2009, 09:41 PM   #20 (permalink)
Super Member
kennyd's Avatar
I believe i have a later tractor , unsure of year ? The # i found was between the return to the tank and the rock arm, you ment part of upper 3pth pivot i think THE# ( 843575 ) A couple of numbers on the pump, 160kgf/ cm2 and discharge 7cc/rev ??? I m unsure GPM
I only know what I quoted above from JDparts (you are registered right?)
If you have the later # above 820001-and it looks like you do, then all I would order from JD is the diverter plug P/N PT13744.
You also might want to find a FSM (factory service manual) on eBay also...
Basically, when you install this plug, it diverts the fluid OUT of one of the ports, through the new valve then back IN the other port whenever the tractor is running.
I would pick a valve, then devise a mounting for it while you are researching everything else...
__________________
JD 4110HST
JD 4x2 Turf Gator
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.23936 seconds with 9 queries
