dcyrilc
Super Member
My power steering is a closed center CC system. Does this mean that the rest of the system has to be CC? Or are some systems hybred using both CC and OC?
CC, Closed Center system also, usually, means that there is a Constant Pressure, CP. Benefit is that a CP system operates more distinct and is more independent of the load pressure. Also can extra control valves be added easily. CP systems usually need a variable displacement pump, like an axial piston pump.
OC, open Center system, means that a fixed displacement pump, ciculates oil thru the open center in the valve. means that there is a Constant Flow, CF. When control valve is operated, center will close down while work port opens. A OC valve needs a power beyond port if extra valves need to be added.
Simplified we can say that, in a CP system, power is regulated by a variable flow, and in a CF system, power is regulated by a variable pressure.
CF systems usually waste more energy at stand by, than CP systems.
There are two other similar variants of CP systems, CPU, Constant Pressure Unloaded, and LS, Load Sensing.
In a CPU system, the pump turn down to a low pressure, 400-500 psi, at stand by. That lower the losses at stand by. It also reduce the crank torque at start up.
LS system, is a constant pressure system that varies the constant pressure whento the load pressure varies. That lower the losses at high pressure. LS system unloads the same way as CPU systems.
There are also LS systems that uses a fixed dipalcement pump, closed center valves, and a dump valve that by pass flow at stand by. These systems are std on the HIAB truck cranes today, valve and system design from Swedens Olsbergs Hydraulic. See this interesting video about casting these valves.
Thanks AKKAMAAN,
Though I didn't really figure out an answer out of that. I suppose I should have given more info...
I'm working on a 1980 JD2240 tractor. I'm not digging into the hydraulics yet, but that will be next after I finish rebuilding the power steering. The tech manual has sections on both OC and CC hydraulic systems and valves for loader, etc...
My power steering is definately CC and I was wondering if this meant the rest of the system would be CC also or if they have been known to hybredize systems. Everything runs off one pump.
I think I just found my answer since you said that OC and CC systems use different types of pumps.
My system should be all CC. Is this correct?
If so, this will eliminate 1/2 the systems in the tech manual for me to dig through to ID the system my tractor is using. My first step for troubleshooting the hydraulic system will have to ID the system in the manual.
I think the type of system, OC or CC, is optional when you buy the JD new, that could be the reason both are in the book, CC better but more $$$. But I need more info to tell whats up. I know that JD has TOP NOTCH documentation so it should be possible to figure everything out.
Would be interesting to see a detailed picture of the pump, maybe we can determine if it's a fixed or variable displacement pump.
Is there any symbol drawings on the systems?
Maybe this will explain it to your satisfaction. For the most part, closed center systems are only used for short term operatons. The variable speed pumps on the Power-Tracs are closed center, and do not maintain the high pressure as some other closed center system , and only provides the pressure/volume when the swash plate is shifted.
Quote:
The principal of close center hydraulic systems is to provide oil flow on demand it enables simultaneous operation of many users connected to one pump.
These systems almost always use variable flow piston pump with swash plate.
There are few exceptions where gear pump is used with special LS dump valve.
These systems offer significant benefits in reducing engine power loss if compared with open center systems where full capacity of the pump, almost always gear pump, is continuously pumped round the hydraulic circuit even when it is not operated.
The unused fluid goes to tank.
