Results 1 to 6 of 6
  1. #1
    Gold Member Slacker's Avatar
    Join Date
    Jun 2005
    Posts
    491
    Durham, NC
    Farmtrac 360 TLB
    Default Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP CUT?
    My cat1 toplink is 18.5" at it's smallest and 30" at it's longest.
    I'd like to replace it with a hydraulic toplink.
    Will this one work? It's 18" at smallest with a stroke of 12", so 30" at it's longest, same as my toplink. Is 5/8" rod large enough to handle a 40HP CUT, 6ft BB and bushhog?
    Thanks for the input guys, I only want to do this once if I can help it.
    https://www.surpluscenter.com/item.a...name=hydraulic
    Double acting
    Bore x stroke 1" x 12"
    PSI max. 3,000
    Rod dia. 5/8"
    Ports SAE 6
    Retracted length 18"
    Shpg. 7 lbs.
    END MOUNTINGS
    Rod end swivel-ball
    Ball width 1"
    Ball O.D. 2"
    Pin hole 1/2" ???
    Base end swivel-ball
    Ball width 1"
    Ball O.D. 2"
    Pin hole 1/2"
    Farmtrac 360 TLB with lots of stuff that hooks to the back.
  2. #2
    Gold Member Cocre's Avatar
    Join Date
    Aug 2008
    Posts
    424
    Sandy Run, SC
    '06 John Deere 3320
    Default Re: Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP C
    The pin hole is too small, plus you will probably need something with a rod diameter greater than one inch and most everyone recommends a lock valve.
    I recently purchaced this one:
    Here is one slightly longer:
    CCM has similar units.
    '06 John Deere 3320
  3. #3
    Join Date
    Jun 2005
    Posts
    491
    Durham, NC
    Farmtrac 360 TLB
    Quote Originally Posted by Cocre View Post
    Wow, that website is a pain for those of us who are Hyrdaulic newbies.
    I don't think I want the lock valve. I don't mind making slight adjustments
    occasionally, especially for $75 extra dollars. Can you point me to the
    2X11X1.18 CAT I HYD DA TOP LINK CYL without the lock valve?
    I'm having a hard time finding it. thanks for the help!
  4. #4
    Join Date
    Aug 2008
    Posts
    424
    Sandy Run, SC
    '06 John Deere 3320
    Before I bought my cylinder with the lock valve, I priced others without. Mostly the cylinders were close to the same price or higher (see eBay search "top link cylinder"). I also believe the lock valve adds a layer of safety to the setup.
    Surplus Center does have this:
    https://www.surpluscenter.com/item.a...59-10&catname=
    But the pin holes are are too big (you can buy bushings) and perhaps the whole swivel eyes are too large.
    The Surplus Center searches I use are "top link" or "toplink" or "swivel eye". You get different things with each search, but I think it covers it all.
    You can also buy a regular welded cylinder and cut the ends off and weld on swivel eyes, but the cost will add up on you quick.
    Here is one from another vendor, but its retracted length is longer than I wanted.
    Hydraulic Top-Link - Category 1
    And a picture of my setup.
    Attached Thumbnails Attached Thumbnails Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP CUT?-20100109-047-jpg
    '06 John Deere 3320
  5. #5
    Gold Member TTTTTT's Avatar
    Join Date
    Mar 2008
    Posts
    266
    Bowmanville, Ontario
    Dong Feng 354 (Oct 2008)
    Check this thread if you missed in a search
    http://www.tractorbynet.com/forums/h...-top-link.html
    I got the Dalton one and love it. It does not have a lock valve and for what I use it for it it is not necessary. Depending on your needs, it may be a necessity. The thread addresses some of the issues.
    Dave
    DF-354 (Oct.2008), Town Sunny 404 Loader,
    Town Sunny 3pt BH -6',
    3pt Log Splitter - 26",
    3pt 12" PHD
    8' Snow Plow Blade adapted to FEL,
    3 pt 7' Rear Blade,
    FEL / 3pt Forks,
    Hydraulic Toplink.
    3pt Hydraulic Crane
  6. #6
    Member
    Join Date
    Sep 2009
    Posts
    45
    Odessa Mo.
    John Deere 5103 FWA, Ford 3610
    I have a Dalton top link to. It is a cat 2 for my 5103 JD and doesnt have a lock valve either. Works good for what I use it for. It is more expensive than the surplus center brand. Mine is a Prince cylinder with a 3" bore x 10" stroke..... Bull
    08 JD 5103 FWA, 553 Loader w/72in bucket
    Frontier RB2196H
    Frontier RC1072
    Frontier Pallet Forks
    Home made carryall
    JD 2-14 plow
    07 JD X540 26hp 54in
    07 Dodge 3500 drw ,45 gal Auxiliary tank, B/W hitch
    07 Yamaha Grizzly 700 EPS, Warn winch & bumper
    88 Starlite 20' GN 14k GVw
    Alot of other stuff
Similar Threads
  1. Toolcat 5610 vs CUT review
    By radman1 in forum Buying/Pricing/Comparisons
    Last Post: 08-29-2013, 03:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
