Results 1 to 4 of 4
  1. #1
    Join Date
    May 2007
    Posts
    67
    Toronto, Ontario
    Kubota B7100,Ford NAA, Kubota L2550GST
    Default Replacing Disconnects
    Greetings;
    I have a kubota L2550 that has a 60" front mounted plow. At the moment it only has hydraulic up/down. The previous owner told me that it did have power left/right control but that the cylinders had seized and he had them removed and the plow converted to manual swing. I'd like to restore the plow to full hydraulic control and the first thing that struck me was that the disconnects for the remaining cylinder have been replaced and the remaining two look original and pretty rough.
    My question is, is there pressure in the lines "back" of the disconnects, or is it simply a matter of unscrewing the old ones and installing the new ones ?
    Lastly, any links to a hydraulics tutorial for newbies would be really helpful. When I source the replacement cylinders and get them mounted I'm sure I'll have lot's of questions about pressurizing the cylinders for the first time.
    Cheers, Erik
    Attached Thumbnails Attached Thumbnails Replacing Disconnects-hydraulic-connectors-jpg
  2. #2
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,482
    Tyler, Texas
    Several, all used and abused.
    Default Re: Replacing Disconnects
    If the engine is off, then there might be a small amount of pressure in the lines from the last time the valve was moved when it was running. As long as the engine is off, you are fine to unscrew them and put on new ones. Gravity will allow what's in the line to drain out, but shouldn't be very much. Depending on what type you have will dictate on how they threads are sealed. Mine don't require any sealant, so I can just take them on and off when I want.
    I have Sechi quick disconnects. I think the spelling is wrong, but if you sound it out, you'll get the idea of their brand. I was told that they are the best, but I hate them. Under pressure, they are impossible to get apart or put togethe. I have to crack the line to remove the pressure on it to get them to work. Fortunately, when I put on my grapple, it stays on for months at a time, so I don't have to do this all the time.
    Eddie
  3. #3
    Join Date
    Jul 2009
    Posts
    197
    Joplin Mo.
    Kubota L 3400DT
    Hello
    There can be pressure between the control and the disconnect.
    After you shut the engine off, move all of the controls and the pressure will go to 0. That is if everything is sitting on the ground and not raised up.
  4. #4
    Join Date
    May 2007
    Posts
    67
    Toronto, Ontario
    Thanks for the info. Replaced the disconnects with only a dribble of oil. One of those questions you don't know the answer to until you ask, or guess wrong!
    Cheers, Erik
Similar Threads
  1. Replacing Fan Belt on a BX2200
    By tomnky in forum Kubota Owning/Operating
    Last Post: 04-07-2017, 08:55 PM
  2. Replacing O ring on loader
    By jddodge in forum Hydraulics
    Last Post: 12-10-2008, 10:44 PM
  3. Bob Cat vs Tractor quick disconnects
    By SCDolphin in forum Attachments
    Last Post: 04-23-2007, 09:49 PM
  4. Quick disconnects on front loader
    By gboyd in forum Parts/Repairs
    Last Post: 05-08-2006, 05:36 AM
  5. Cleaning quick disconnects
    By Vermonster in forum New Holland Owning/Operating
    Last Post: 09-10-2002, 12:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
