I have a 1999 JD 4200 that has a hydraulic problem. The power steering is working fine but the front loader lift and tilt has started operating only at high RPM. Low Rpms it will not move at all. The 3 point hitch appears to operate normally but it has no load on it so I'm not sure about it.
I Drained the hydraulic oil, cleaned the suction strainer, changed the hydraulic oil filter and refilled with oil.
Strainer was clean, there are no oil leaks. I inspected all suction lines and no cracks were found. I disconnected the tilt lines and tried the lift fuction and would not lift at low RPMs. I reconnected the tilt lines and disconnected the lift lines and would not lift at low RPMs.
Local dealer of no help only wants the repair job. I am capable of any repair if I can pin point the trouble.
Any help would be appreciated!
Dan
Sellersburg IN.
Dan
Sellersburg IN.
