ss4010
Hi,
I purchased an old heavy duty boxblade that came of a MF 30 E? With it came the top link hydraulic cylinder. So I figured since the cylinder was sitting outside for at least the last 10 years and there was signs of leakage I would attempt to rebuild it prior to attaching it to my machine.
Easier said than done. I can't seem to figure out how the cylinder can be disassembled. It is a 3" diameter cylinder with 1524 and 2189 stamped on the sides of it. Aside from that there are no other markings. I removed what looks to be a retaining spring (or some sort of shield) that is two full rotations. Besides that I don's see any way to take this thing apart. There are no holes or anything that one might use to unscrew the end of the cylinder.
Attached are pictures of the cylinder (after wire brushing it clean) and knocking most of the rust off.
If anyone knows how to take this thing apart, please enlighten me. Also if you have any ideas as to the make and model of the cylinder that would be very appreciated.
Thanks,
Steve
Thanks,
Steve
