Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member Grammargarcia's Avatar
    Join Date
    Mar 2010
    Posts
    9
    Rapid City, SD
    Default Manual to electric control of control valve
    Howdy,
    I am in the process of building a dump trailer and my father-in-law gave me a hydraulic pump for this project. It however has a manual control valve. I am trying to see if anyone has done this changeover? I will post a picture in next day or so. Thanks for any input.
    Zeus
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: Manual to electric control of control valve
    Welcome to TBN
    A picture may help, but I suspect you will end up paying to much in time and money for this "free" pump if you try to modify it to much.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Join Date
    Mar 2010
    Posts
    9
    Rapid City, SD
    I have this same ugly feeling, but I will get a picture once their is some daylight.
  4. #4
    Join Date
    Mar 2010
    Posts
    9
    Rapid City, SD
    All,
    So I took a view pictures. It has quite a bit of ugly but it does work. Any suggestion would be greatly appreciated.
    Thanks,
    Zeus
    Attached Thumbnails Attached Thumbnails Manual to electric control of control valve-100_3230-jpg   Manual to electric control of control valve-100_3235-jpg   Manual to electric control of control valve-100_3231-jpg   Manual to electric control of control valve-100_3233-jpg
  5. #5
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    I can't think of any easy way to convert that...Unless you can find a large solenoid or small linear actuator to move the valve.
    KennyD
    www.boltonhooks.com
  6. #6
    Join Date
    Mar 2010
    Posts
    9
    Rapid City, SD
    I was thinking along the lines of an actuator, but where to find one? I have looked a little on the web. Most are wholesalers. Any thoughts.
  7. #7
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    Surplus Center is one that has a great reputation for hydraulics and such, They also have a decent selection of actuators.
    KennyD
    www.boltonhooks.com
  8. #8
    Join Date
    Mar 2009
    Posts
    242
    An easy way would be to permanently lock the manual valve in the open position. Then put a 3 way solenoid valve on the manual valve output. Plumb the common port back to your cylinder, the normally open port to tank (for lower) and the normally closed port to the manual valve output (for raise). There should be an internal relief valve to prevent the pump from blowing up.
    ISZ
  9. #9
    Join Date
    Mar 2010
    Posts
    9
    Rapid City, SD
    Kenny D and ISZ,
    Thanks for the input. I am going to try a 12v solenoid which will take the place of the lever.
    I have a general question. What is the opinion of the all about hydraulic fluids. I am wondering just for education reasons. The hydraulic repair shop here suggested dextron III because of the low temps during the winter, but is their a downside to it in the summer?
    Thanks a bunch,
    Zeus.
    P.S. I am just about done gathering all my steel for the dump trailer I am building. I will post pictures as things progress.
  10. #10
    Silver Member glastron23's Avatar
    Join Date
    Nov 2009
    Posts
    249
    atlantic canada
    you can change out the manual control for an electric unit, will require a new spool valve,solinoid and electric control handle. as far as the Dextron , will not be any problems with the summer usage. http://www.princessauto.com/componen..._schematic.pdf
    this unit is very close to your unit, i think yours is an older model, check with the manufacture/good hydraulic shop for the parts required. Jim
Similar Threads
  1. splitter control valve...
    By mrcaptainbob in forum Hydraulics
    Last Post: 01-29-2010, 09:38 AM
  2. L3400 L2800 Position Control Valve Research
    By Harvest Moon in forum Kubota Owning/Operating
    Last Post: 12-10-2008, 06:17 PM
  3. BX Control Valve Question
    By ewoz in forum Kubota Owning/Operating
    Last Post: 11-18-2008, 09:13 AM
  4. Where to Put Rear Hydraulics Levers
    By glennmac in forum Customization
    Last Post: 05-16-2006, 09:24 PM
  5. Grease fitting on LA302 control valve
    By texblonigan in forum Kubota Owning/Operating
    Last Post: 04-24-2002, 02:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
