Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    Feb 2002
    Posts
    23
    Elko, MN
    Kubota B2910
    Default Kubota B2910 Hydraulic Leak
    Hello,
    Any kubota B2910 experts out there?
    I have a hydraulic leak on my B2910. See attached photos. It appears to be an inset Allen head bolt and is leaking from its center. What is this part and why is it leaking?
    Also, what is the tapped hole on the top of the housing (next to the scratches)? Should there be a bolt or plug in there?
    Thanks in advance!
    Attached Images Attached Images
  2. #2
    New Member
    Join Date
    Feb 2002
    Posts
    23
    Elko, MN
    Kubota B2910
    Default Re: Kubota B2910 Hydraulic Leak
    Another photo.
  3. #3
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Hi,
    I tried to take a look at my B2910 but could not see that point because of the seat assembly blocking the view. Maybe after dark I can look again with a flashlight/mirror or something...at least to see if mine also has an empty threaded hole in the top...
    Mabye someone else can offer more help...hope so!
    Bill Macher...in Pgh, PA...zip code anyway...
  4. #4
    Super Member ronjhall's Avatar
    Join Date
    Apr 2000
    Posts
    9,305
    SE Michigan
    Kubota 2910 HST
    Elkoboy
    According to my 2910 Illustrated part list. The item that is leaking is a plug. It may need tightening or some thread sealant. Do not use Teflon tape.
  5. #5
    Advertiser
    Join Date
    Apr 2000
    Posts
    1,589
    Western New York
    Kubota B2710
    Elkoboy,On my B2710 the threaded hole is for a clamp for the wiring harness. And I can see the plug on the side. I would try tightening it and see it that stops the leak.
  6. #6
    New Member
    Join Date
    Feb 2002
    Posts
    23
    Elko, MN
    Kubota B2910
    Thanks for the quick replies!
    Unfortunately, the plug looks to be painted into the housing, and won't budge, and I hate to force it.
    Any ideas?
  7. #7
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,676
    Nova Scotia, Canada
    Perhaps tap it with a hammer or apply some heat to it.
    Or if it's in a non pressure spot clean off the oil real good, get it dry and put a gob of silicone over it. Use duct tape to hold silicone in place till it cures.
    Egon
  8. #8
    New Member
    Join Date
    Feb 2002
    Posts
    23
    Elko, MN
    Kubota B2910
    RonJHall,
    Why do you advise to not use Teflon tape? I have had a couple of mechanically-savvy people tell me to use Teflon tape, as well as the local kubota dealer that does service on my tractor.
  9. #9
    Join Date
    Jan 2001
    Posts
    2,518
    Capital District, Upstate New York
    Satoh S650G, MF135, MF165, JD5205
    <font color=blue>...Why do you advise to not use Teflon tape? ...</font color=blue>
    If pieces of "teflon tape" are introduced into the hydraulic system... they can be very unforgiving... it can destroy a hydraulic pump rather quickly...
    I'd clean the entire outside surface to determine exactly where the leak is originating... sometimes the "puddling" is deceiving... ending at the spot you're viewing... and not coming from...
    Normally with the higher pressures involved in hydraulic fluid systems... the silicon sealant fix will normally rupture in a short period of time...
  10. #10
    Join Date
    Feb 2002
    Posts
    540
    Mukwonago, WI
    BX2200, '52 8N
    What you would want to use is Loctite 542 Hydraulic Thread Sealant. Remove the plug and clean both the plug and threads on the cast part(use a Q-tip) real well. Then apply the sealant to the plug. Or you could buy a new plug which is less than a buck which comes with thread sealant already on it. The later choice is probably cheaper than buying the sealant, but if you think you may have/get leaks in other places go buy the sealant.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
