Yanmar1401D
- Joined
- Jul 5, 2010
- Messages
- 10
Appreciate any help! really new with this hydrualic thing but here it goes. I bought a 3pt backhoe for my tractor and taped into the existing hydraulics. I thought I had the high pressure / return lines correct but when I hooked it up to the backhoe needless to say I heard a pop an fluid started leaking out of the spool valve. I took apart the spool valves and saw that there were o-rings in between. Replaced all and put back together. Still leaking Can someone enlighten a green horn what happens when I hook it up backwards to the spool valve and also what else maybe leaking?. It is a slow leak that comes out the bolt holes right at the end of the stacked valves. Are all the spool valves ruined?
Help!!!
thank you
Help!!!
thank you
