Jackfr
Gold Member
- Joined
- May 28, 2008
- Messages
- 321
- Location
- Plymouth, MA
- Tractor
- NH WorkMaster 33 Ford F5000 NH T 4.90 Ford 2110 JD555B
We have a Ford 6640 with a 7411 loader. It doesen't have any lift or curl power unless you deadhead a rear remote. I started this thread back the beginning of May http://www.tractorbynet.com/forums/new-holland-owning-operating/172954-f6640-loader-problem.html It explains what I ve checked so far. We are finally catching up with spring planting chores and have had time to check a few more things. I disconnected the linkage and operated the spool valve directly at the valve to make sure I was getting full travel because of the worn linkage. This made no difference in the loader operation. I checked the signal line pressures from the rear remotes to the proportioning valve and the pressure is 2550 psi but the pressure on the signal line from the spool valve is only around 1600 psi unless you deadhead a remote at the same time as using the loader spool valve then the pressure jumps to the 2550. I checked the check valves as RickB suggested and they appear to be clean and working properly. There is a "hissing" noise when hoisting or curling the bucket coming from the spool valve like you were feathering the valve. So far everything points to the signal from spool valve being the problem as the loader will work fine with plenty of power if you keep a remote deadheaded. That's how we've been using it (hopefully not causing further problems). I have the service manuals for this tractor but don't have any experience in taking apart/rebuilding spool valves. The online NH parts manual lists numerous kits for rebuilding this spool valve, not sure which ones I need. Anyone with suggestions before I jump into this? To replace the linkage and spool valve from NH the parts are close to $3000. Does anyone know where I might buy an after market spool valve joystick combination with a signal line port I have had no luck in finding one or should I try taking this valve out and try rebuilding it.
