I dont know about this specific valve.....needexplosion part list or cross section drawing....
but except from getting linkage and end caps off, it's not that hard ....just be careful use common sense
It believe it is these low pressure O-rings that are leaking....CHECK OUT WHAT CAUSES RAISED PRESSURE IN RETURN LINE!!!!
example how it can be layed out...I used this picture for another thread....THIS IS NOT YOUR VALVE!!
I can not exactly see where it is leaking.
Is this still on warranty with 25 hours?
Just guessing where it is leaking, probably not to difficult to fix.
Can't help on the leaks but the lowering of the BH and the stabilizers is common, even with no leaks. I have a hooked rope tying the stabilizers together and put the pin in the BH when not in use.
