Fordgpw:
I will trade this for some later help on what your name implies.
That is a nice looking rig. I have a similar arrangement with a 455D, but my backhoe is the older 9300 model with the barrel shaped swing motor rather than the newer swing cylinder feature of yours. My swing motor is leaking badly around the upper shaft seal and I am going to rebuild it on my Thanksgiving holiday.
These pictures show how someone else did it.
ImageShack Album - 10 images Seems to me the hydraulics will be the hardest part.
I suspect the hydraulics are about the same on your 350 as my 455. There are two 1" hoses that quick connect to the backhoe, as you said. One is a pressure line from the power beyond port on the front end loader directional control valve, and the other is a return to tank. As you also know, when the backhoe is removed those hoses must be connected to each other so the power beyond from the FEL valve has a path to the tank on the crawler. My FEL valve has three sections: one for the booms, one for the bucket, and a third spare that is not used now but is available for a 4-way bucket.
If only one rear cylinder were needed, and if your 350 also has that third FEL valve section, you could use it by just running a couple of 3/8" lines from the FEL valve.
But I assume you will need three circuits: one for the lift cylinder on the TPH you are going to build, one for the tilt, and one for the tip.
That means a new three spool valve with a flow rating to carry all the pump output. I believe the pump on the 455 is 23gpm, but I am not sure. If so a 25gpm valve will be adequate. I suspect you will have to buy a fairly expensive ($500 or more) sectional control valve from Surplus Center or the like and add a joystick kit for two of the spools.
Then you have to plumb the new valve into the power beyond flow coming out of the FEL valve. You have at least two choices:1. put the new valve in the PB line where the backhoe was (figuratively) or 2. put the new valve in the PB line where it exits the FEL valve. #1 is not very elegant, because you will need to have two 1" lines with quick disconnects on one end to connect to the backhoe pressure/return lines when you take the backhoe off; and those lines will snake from the rear (where they connect to the pressure/return lines), under the floor, and then up onto the side console where they will connect to the pressure and tank ports on the new three section valve. Then the six work lines from the three section valve will snake back down to the rear and attach to the lift, tilt, and tip cylinders. Although this approach is not elegant, it is probably the easiest to execute. But it is the most expensive because it will require two 1" quick disconnects and 12' or so of 1' hydraulic line.
Choice #2 is more professional. Break the pressure circuit where the PB line now leaves the FEL valve and insert the new valve there. There will be one line from the PB port of the FEL valve to the pressure port of the new valve and one line from the tank port of the new valve back down to the PB line you just disconnected. The problems with this approach are twofold: 1. the PB line from the FEL valve is, if I recall right, 1" metal tube and not easily bent, if at all; 2. the space around the FEL valve is pretty tight, and it will be hard to use the fairly stiff 1" hose in the short distance from the FEL valve PB port to the new valve pressure port. And you will have the same problem with the 1" return line from the new valve tank port to the end of the now disconnected PB line. Unless you have a storage rack full of various hydraulic fittings and the ability to make your own hoses, you might spend a whole day just getting these two lines hooked up.
I have to ask if the box blade will function very well behind the 350? I have a box blade and have a hard enough time on a small wheeled tractor looking back to see what is going on enough to control it. I am not sure I could even see the box blade behind the 455 without kneeling on the seat backwards. Controlling the height would be hard enough, but to make the judgements and (relatively) delicate adjustments required of the TNT (I am only guessing since I don't have one) would be nearly impossible.
If this does not discourage you, I have some thoughts on a quick and dirty way just to try it out. Got to run, but let me know if I should ramble on further.
Good luck and send us pictures.
