OP
rswyan
Super Member
- Joined
- May 12, 2004
- Messages
- 9,771
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Well ...... this is getting to be quite the ed-u-ma-kay-shun .....
There's not much in the way of "hill" here .... there's a pretty gentle grade from the house to the top of the driveway, and the road after that (which I also clear) is basically flat - but I get the point:
If ya use all the HP to drive the pump/motor/blower and ya ain't goin' anywhere ...
Usually I blow from north to south, down the driveway (downhill) - to avoid having snow blow back in my face (wind is often out of the north it seems)
I did some checking on Allied/Buhler's website and found that they make a 60" commercial snowblower that is hydraulically powered for skidsteers. The power requirements are listed as 13 to 22 GPM @ 2000 psi:
Farm King Commercial Snowblowers
Interesting ....
Ran across the following thread by Pks on a snowblower conversion to hydraulic he did for a friend back in 2006/2007 .... but it's leaving me with more questions than answers :
Hydraulic Snow Blower for FEL
.... although he states things were sized for 20 HP, there's a good bit of missing info in the thread : .... the model and exact HP of the tractor (it's a JD and has a model 70 loader on it), and the exact width of the blower (he said it was "only about 44 inches wide" - but the tractor & blower look alot bigger than the single-stage 42" blower that I have for the old Cub Cadet 782)
The one Pks did uses the mid-PTO of the tractor and was designed for an max of 2600 rpm input, with 2000 rpm input typical.
He also said he thought the hydraulic pump and motor were both 2.25 displacement .... the pump is a Prince and the motor is a Char-Lynn apparently .... he was going to get back and post the exact model numbers (along with pics of the pump and drivetrain) ... but never did ...
Claimed that the system was designed for 3000 psi max, but that 1850 psi was the typical operating pressure ...
Something like this maybe:
3/4" NPT 30 GPM CHECK VALVE 5 PSI CRACKING
Yeah .... that's been running across my mind the last day or so as I've been pondering all this ....Also, don't forget to allow for drivetrain power requirements in your calculations. If you use all of your power for the snow blower you won't have any left to drive up the hill.
Interesting ....
Right - basically it would be plumbed between the return from, and supply to the motor - so that flow from the return line could feed over to the supply side when the pump is shut off, correct ?hydraulic motor coast down circuit. In normal use the check valve is closed, but if the oil flow stops suddenly the hydraulic motor can coast down at it's own speed and not self destruct.
RightIt also will not allow reverse rotation of the motor, which can be nice when you want to prevent someone from hooking the hoses up backwards.
