Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,433
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Default Re: Power Beyond or HPCO valve help needed
    When taking fittings apart, which would you rather clean up before reassembly, paste or tape?
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  2. #22
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Neither one is difficult to clean up. The people that get in a hurry are the ones who forget.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #23
    New Member bbutcher's Avatar
    Join Date
    Nov 2010
    Posts
    21
    Longmont, Colorado
    Satoh S650G
    I just took the Gesen V12 valve apart and built a power beyond adapter to fit it. I posted several photos and a dimensioned drawing in my photo album, Bobs Backhoe on this site. I will put it back together and test it in a few days if the weather holds out. Hopefully this will avoid the problems with too much pressure on the seals of any valve in the system.
    Attached Thumbnails Attached Thumbnails Power Beyond or HPCO valve help needed-dscn3935-jpg
  4. #24
    Join Date
    Nov 2010
    Posts
    21
    Longmont, Colorado
    Satoh S650G
    The original adapter I built had a 1/4 NPT internal thread, but no standard hydraulic fittings are available to fit a 3/8 hose. A 3/8 NPT would work, but the wall thickness would be rather thin, so I changed the design and used a O-ring seal type fitting with a 9/16-18 thread. This will accomodate a standard 3/8 hydraulic fitting and provides a better seal with plenty of wall thickness, although it takes a little more machining. A PDF version of the drawing is attached.
    Attached Files Attached Files
Similar Threads
  1. Dealer Reputable Dealer
    By rmully in forum Yanmar
    Last Post: 05-06-2010, 10:55 PM
  2. Power Beyond Add a Valve
    By lekwyo in forum Hydraulics
    Last Post: 02-05-2010, 08:35 PM
  3. 4500 remote hydraulics
    By T King in forum New Holland Owning/Operating
    Last Post: 11-03-2007, 12:44 AM
  4. Replies: 2
    Last Post: 09-20-2007, 10:32 PM
  5. Adding another set of rear hydraulic lines.
    By JimR in forum Hydraulics
    Last Post: 06-08-2007, 09:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
