Follow up to my thread about welding on a hydraulic cylinder
   / Follow up to my thread about welding on a hydraulic cylinder #1
allen in texas
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
Here's the thread with a pic of my ugly temporary fix
http://www.tractorbynet.com/forums/hydraulics/188493-welding-hydraulic-cylinder.html
Here pics of the mods I made on the top link from 3240 for my
permanent fix.
#1 The cylinder before I cut the end off
#2 The 1 7/8 inch OD by 1 1/8 ID (3/8 wall) 6 inches long pipe.
#3 End cut off
#4 Parts all welded together
#5 Painted and ready top use.
Now my 5740 has a hydraulic top link that is long enough. :)
I was going to put up some pictures with the box blade attached to show why I want so much length and travel in my top link but my son's truck was parked in front of my barn door and I don't have keys for it.
Couldn't get my tractor out. :( Maybe tomorrow.
Ps...
no one makes a hydraulic top link as long as I want for a Cat1/2 tractor.
The longest I found was 34 inches extended.
Mine is 38.
my cylinder's longer than yours is, my cylinder's longer than yours...
Oh,
Sorry:D
Now...
Pictures of why I want a long top link with a good bit of travel.
#1 The box blade level
#2 On it's nose. the scarifers can go 6 inches into the ground before the blade touches.
#3 On it's tail. I can feed material as large as 2 3/4 inches under the front blade.
This works really well. Stand the boxblade on it's nose and rip it up, level it and back in and drag it out and then spread it when you get where you're going.
   / Follow up to my thread about welding on a hydraulic cylinder #4
Looks to me like you did a nice job.. what did you weld it with (rod and type of welder, and how many amps ?)
James K0UA
   / Follow up to my thread about welding on a hydraulic cylinder #5
That looks sweeeet....!!......:thumbsup:
James K0UA
Miller 250 wire welder. Lincoln wire, straight co2 gas, 20 volts, wire speed 225.
   / Follow up to my thread about welding on a hydraulic cylinder #8
You have become my inspiration for my newest project.
   / Follow up to my thread about welding on a hydraulic cylinder #9
Nice job Allen.
You get much splatter on straight CO2 ? Have you tried the 75/25 mix ?
   / Follow up to my thread about welding on a hydraulic cylinder #10
good job! We do that same exact type of welding on cylinders here for a "special order" type like you wanted
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
2025 CFG Industrial MX12RX (A50123)
2025 CFG...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2004 Ferrara Pumper Fire Truck (A51692)
2004 Ferrara...
