Adding 3rd function valve, top link, side link, and one extra. How???
   / Adding 3rd function valve, top link, side link, and one extra. How???
So after looking a little more, i found that the 4610 has a hyd flow for implements of 9.6 gpm, so I assume that means that I'll have to step up to the next valve size? being the 14gpm rated one?
Is this what I need? Surplus Center - 4 SPOOL 14 GPM PRINCE WVS41BBBB5C1 DA VALVE
If so, what about the diverter, which one could I use?
Other than that I guess all I'll need to buy is QD fittings, hose, and a 12 pack for a long day of learning....
I can make up some type of bracket for the mounting I suppose, unless they sell one for this?
I know it's not an easy job but I'm eager to learn.
Also, as for the fittings, is that an entirely different subject altogether or is there sort of a standard that I can buy? I hope there aren't too many choices. :)
   / Adding 3rd function valve, top link, side link, and one extra. How??? #12
I just wanted to agree with getting the 4Th remote if at all possible. If you have the room, get it, now is the time to do it.:thumbsup: I know that for me and my implements, I need 4 and I only have 3 at the present time, but that is going to be changed this year. :cool2:
TEG,
I looked at your install report you did, GREAT job and thanks for sharing, it will come in handy. What is the needle valve used for? Do I need one of those?
MtnViewRanch,
After looking some more, I think well jeesh it's only 60 bucks extra for me to get a 5 spool!
haha, I guess the available room is the limiting factor. I'm definately going to go with the 4 spool if room allows, if not I'll find a way :)
I'm trying to think of what I would need it for though, and I can't think of anything? What do you need it for?
   / Adding 3rd function valve, top link, side link, and one extra. How??? #14
Your funny, :laughing: go to Discount Hydraulic Hose (DHH) and you can get all of your stuff from them if you are going to do this yourself. Check, re-check and then check again to be sure that you get ALL the right stuff the first time. I would use JIC fittings every where that I could.
   / Adding 3rd function valve, top link, side link, and one extra. How??? #15
TEG,
MtnViewRanch,
Don't laugh, on my bigger tractor, I'm going to add 2 more, so I will have 5 at the rear.:thumbsup: I'm only going to add a diverter valve on my smaller tractor, so it will only have 4.
What do I need them for? 2 for "TnT", 1 for angle on rear blade or landscape rake, 1 to offset the boom on rear blade or landscape rake. I could use the 5Th one to tilt the rear blade a lot, but I have found that tilting the rear blade with the tilt cylinder of the "TnT" is more than adequate. :thumbsup: You can see in the pictures that I had to not use the offset hydraulic. ( it sets in with my tools) At present I only use a hydraulic for angling the blade and have to manually set the boom when it needs to be offset. :ashamed: :(
   / Adding 3rd function valve, top link, side link, and one extra. How??? #16
There is also a detent kit available for this valve.
Match the diverter with your tractor GPM.
   / Adding 3rd function valve, top link, side link, and one extra. How??? #17
You put a 5 spool on,,,,you'll find you need 6. :laughing:
   / Adding 3rd function valve, top link, side link, and one extra. How??? #18
There was a guy on TBN that had a bigger Kubota that had 6. He had "TnT" and an all hydraulic rear blade that required 4 controls.
angle
tilt
offset
hydraulic gauge wheels
If I remember right, he had a grapple also, so he had a total of 9 controls, now that is a lot of controlling to do. :confused2:
   / Adding 3rd function valve, top link, side link, and one extra. How??? #19
OMG, I'm running out hands to control all the levers ! :laughing:
With enough money and TBN backup, we can put an hyd outlet anywhere. :laughing:
   / Adding 3rd function valve, top link, side link, and one extra. How??? #20
That valve is perfect. I second the use of JIC fittings whenever possible-but there will still be NPT and ORB's needed in spots as well.
I suggest buying the valve(s), and getting them mounted before ordering any fittings or hoses so you can draw up a "map" of everything needed. You will need to fab up your own mounts.
Do you want to go the "diverter" route or the solenoid valve route?
2025 Unused SDLGC80 Electric Golf Cart (A55853)
2025 Unused...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
UNUSED FUTURE 14' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 14'...
2019 Deere 550K (A53317)
2019 Deere 550K...
2015 JLG M600JP TELESCOPIC MANLIFT (A52707)
2015 JLG M600JP...
2018 Chevrolet Impala Premier Sedan (A55853)
2018 Chevrolet...
