Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Mar 2011
    Posts
    14
    Default 11 hp greyhound pump mount
    hi there,im repowering my old log splitter with a 11hp greyhound from hf,and dont know which pump bracket i need for the pump.the engine is the same thing as a honda 340cc but the honda has a 3 31/64 1in shaft but the greyhound has a 2 7/8 1 in shaft,im using a 16gpm 2 stage barnes pump with 1/2 x 1 1/2 shaft.i have 2 options that i know of,one mount is 5 5/8 long and the other is 4 7/8 long,the honda with the longer shaft calls for the longer one but i dont know if it will work on the greyhound eith the shorter shaft and im bangin my head off the wall tryin to figure this out,but my math skills leave somrthing to be desired lol.could anybody help me out with this please?it would be very appreciated,thancks in advance
  2. #2
    Join Date
    Mar 2010
    Posts
    715
    Default Re: 11 hp greyhound pump mount
    I recently put a HF 6.5 on my splitter w 11gpm pump.I picked up the love joy etc. at northern they,ll help you out.Each side needs a differnt size coupling which is where the love joys come in ,you know the rubber cog from engine to pump.You,ll also need a pump bracket to hold the pump to the engine if you don,t have one.Dave
  3. #3
    New Member
    Join Date
    Mar 2011
    Posts
    14
    the pump mount is what im having trouble with,i dont know which one i need,they have two lenghts,5 5/8 or 4 7/8,the lovejoy is no problem,i just dont know which bracket i need,the 5 5/8 or 4 7/8 to get the proper clearence for the love joy.if the engine were a honda i would have no problem deciding cause they list the honda motor to match up a bracket,but with the greyhound they do not list it for a bracket application.the only difference is the shaft length on the greyhound is shorter than the honda.
  4. #4
    Join Date
    Mar 2010
    Posts
    715
    My 6.5 HF was the same as the Honda and I,d bet your HF will be the same as the larger Hondas.Got a Northrn Tool near you?They,ll hook you up
  5. #5
    New Member
    Join Date
    Mar 2011
    Posts
    14
    i think i got it figured out now,thanks for the reply
Similar Threads
  1. Posthole Digger What PTO HP am i looking for?
    By ajwren in forum Attachments
    Last Post: 10-11-2010, 11:10 AM
  2. Dealer Reputable Dealer
    By rmully in forum Yanmar
    Last Post: 05-06-2010, 10:55 PM
  3. Briggs 11 HP oil seal con
    By Craig Clayton in forum Parts/Repairs
    Last Post: 05-02-2010, 10:01 PM
  4. PTO Pump
    By bindian in forum Mahindra Owning/Operating
    Last Post: 09-29-2007, 10:19 AM
  5. IH 384 injector pump issues
    By CGTech in forum Case-IH
    Last Post: 09-14-2004, 08:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
