Results 1 to 3 of 3
  1. #1
    New Member kasedian's Avatar
    Join Date
    Mar 2011
    Posts
    20
    Kansas
    Ford 1900
    Default 303 Tractor Fluid
    Just wanted to know if anyone knows if this stuff is worth a carp. Can I use it instead of the Ford 134 fluid and be ok? Its on sale at Orschelns for $25 for 5 gallons. Thanks
    Hydraulic Fluid
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 303 Tractor Fluid
    what does the specs on the can say?
    does it meet M2C134D spec? Most generic UTF's do...
    here you do.. i did your homewok for you..
    •Manufactured from base oils selected for their purity and thermal stability, this product contains a premium additive package to provide wear protection and anti-oxidant properties while being compatible with O-rings, seals and packing materials.
    •Contains extreme pressure additives to protect gears and working parts of pumps and hydraulic equipment.
    •Excellent water separation and anti-foaming characteristics.
    •Blends safely with all OEM fluids.
    •May be used where the following fluids are recommended: AGCO, MF, White: PF821, M-1127, M-1129, Permatran®, Q-1722. Allison: C-3. Case/IH®: IH-143, -145, MS-1204, MS-120-5, MS-1206, Hy-Tran®. Caterpillar: TO-2. Ford, New Holland: ESN-M2C, 134B, C. John Deere®: j20A, B(Hy-Gard®), J14B (303), J14C.
    It meets 134C spec., not the newest 134D spec.
    what are you putting it in? Helps to mention that. If it's a ford / NH product from about 1998 or earlier.. it likely specs the 134C fluid...
    if it's your ford 1979-1983 era model 1900 then it's more than fine.
    soundguy
  3. #3
    Join Date
    Mar 2011
    Posts
    20
    Kansas
    Ford 1900
    Thanks Soundguy. You are a wealth of information. Very pleasant, too.
Similar Threads
  1. 303 oil from TSC
    By Soundguy in forum Oil, Fuel & Lubricants
    Last Post: 02-19-2011, 06:52 PM
  2. Wanted: Vicon 303 Fertilizer Spreader
    By Dukes in forum Buying/Pricing/Comparisons
    Last Post: 01-05-2011, 04:18 PM
  3. FYI tractor supply 303 generic oil 24.99
    By mikereid in forum Yanmar
    Last Post: 05-21-2010, 04:23 PM
  4. Looking at a ALLIS 303 Baler
    By Baranx4 in forum Attachments
    Last Post: 05-12-2009, 07:59 PM
  5. Will a #303 snowblower fit???
    By tiny1 in forum Cub Cadet Tractors
    Last Post: 01-13-2009, 10:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
