Dented cylinder
   / Dented cylinder
I have absolutely no clue why I mounted the cylinder like that, I wondered myself from time to time. I think what happened was I had the bucket curled all the way to dump with the grapple open. Cylinder completely retracted. I was trying to close it over a log. With that jaw it is the only way I have found to be able to close on a log. What happens is the grapple gets forced further open by down bucket pressure. There is interference between the jaw and the cylinder. I need to do 3 things , Buy a new cylinder, make the jaws longer and put a hard stop on the jaw motion.
Picture tomorrow of the damage. The fixes will have to wait a month. I have to go on vacation. Bummer.
   / Dented cylinder
Pictures
Obvious problem is the mechanical motion can go past the cylinder . Hard stops will fix it, The rod also bent right near the end. That would have had to happen first to allow the grapple bar to hit the cylinder.
BTW the FEL lift cylinders are also 180d reversed as seen in the last picture. They came from the factory like that, do you think I should turn them around?
   / Dented cylinder #13
No, they are not reversed IMHO. They are that way since the hoses come from the loader frame. In other words-the hose do not move as the cylinder extends to raise the bucket.
   / Dented cylinder #14
I would not attempt to make the "THUMB" jaws longer as that would screw up that model's designed geometry between the length of the jaws and the length and angle of the hydraulic cylinder pin bases. The "THUMB" website shows several different grapple lengths that vary in shape and angles-see if you can swap yours out with a ready made longer product or just buy a new one and sell the other in our classifides section.
Here is what I'm in the process of installing-see that the grapple teeth close in an "over bite" position and not inside the bucket.
Leave the tractor FEL cylinders alone as they are properly installed.
   / Dented cylinder #15
This is a nice set up! Every part looks to fit together well and it appears that it would be a pleasure to use.. Congrats
   / Dented cylinder #16
6sunset6,
Is it my imagination or are those hyd rods close to collision...
   / Dented cylinder #17
wdchyd,
I think you are right. if the bucket is rammed into something, there goes a bent cyl rod. I think I would install a mechanical stop limiter on the bucket.
   / Dented cylinder
6sunset6,
Yikes Never noticed that before. I have had that set up since July 07. Came from the dealer like that.
Must just miss because the rods are not scored. Scary. I bet it is closer with the Skid steer plate than with the original pinned bucket. Have to look at that I think. Thanks for the heads up.
   / Dented cylinder #19
wdchyd,
I imagine the chance of a collision with the right conditions will easily happen. I agree with JJ's idea of a mechanical stop for the bucket.
   / Dented cylinder
More pictures There is no damage to the rods. By the time the rods are close enough to hit there is no motion left, it is just press . Lucky. You can see that there are welded beads on the contact pads on the loader arms. Obviously the factory caught the problem and attempted to fix it with a short term solution. You can see in the last picture depressions worn in the pad on the quick attach side. Solution is to weld 1/4 maybe 5/16 thick pads on the loader frame side.
I would suggest that any one with a NH 240 / 250 or other curved arm loader to take a look at their machines.
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
Push Mower (A59231)
Push Mower (A59231)
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
Case 930 Tractor (A59814)
Case 930 Tractor...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
