Hi All from new member Bob S need help on kubota hyd's
   / Hi All from new member Bob S need help on kubota hyd's #1
Bob S
Lewiston Michigan
Kubota B2610
I have two tractors--Kubota B 7610---AC 6060(for the big stuff)
My latest project is to put a clam set up on the Kubota bucket--the problem is I'm out of hyd. taps. Need info on tapping the system to add a two way cylinder. Also don't understand the (power beyond) line. Thanks Bob S
   / Hi All from new member Bob S need help on kubota hyd's #2
Welcome to TBN. :)
   / Hi All from new member Bob S need help on kubota hyd's #3
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Hydraulics Forum. You'll get a better response there. ;)
   / Hi All from new member Bob S need help on kubota hyd's #5
As far as the PB, if your valve has a PB outlet, you can add another valve in series with the other valves. You can also add a solenoid controlled selector valve that uses the bucket curl hyd supply. No voltage uses one side of the valve. When voltage is applied, the hyd shift to the new cyl, and your curl lever controls the action.
https://www.surpluscenter.com/item.asp?item=9-5117-A&catname=hydraulic
   / Hi All from new member Bob S need help on kubota hyd's #6
If your looking for PB info do a search in hydraulics there is a lot and I learned everything I know about the subject from the threads. As far as J_J suggestion, that's the way I'm going. The only difference is I'm using this selector: https://www.surpluscenter.com/item.asp?item=9-7852&catname=hydraulic . It's $10.00 cheaper and only has one electrical connection. If you look at this site: ANBO Manufacturing Hydraulic Diverter Valve , they sell the exact same valve (haven't found a price to compare) as part of their "Hydraulic Diverter Valve Kit". The first 2 picks are PWR Beyond, one with and 1 without it being used. The 2nd 2 show a variable pump were pwr beyond is not needed.
Thanks for the info JJ--looks like elec/hyd is the way to go. Also thanks to ch47dpilot, the picks help alot. Thanks to all Bob S
THANKS Bri
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
2021 CATERPILLAR 926M WHEEL LOADER (A52709)
2021 CATERPILLAR...
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
