Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jul 2009
    Posts
    5
    Default Quick Connect
    Currently have 2 quick connects at rear of tractor that I installed for backhoe (PBY & Return). I am able to connect Backhoe, Dump Trailer or Grapple Valve as needed but obviously one at a time and plugging the two together when attachments are not in use. Is there a diverted or valve that could be installed so the 2 grapple lines could be permanent and still have two quick connects for the other attachments? Attached is a diagram of what I would like to end up with.
    Thanks in advance this site has been very helpful for a novice in hydraulics. Converting the grapple from the original electric/hydraulic to hydraulic was a vast improvement and the help from this forum was appreciated.
    Attached Thumbnails Attached Thumbnails Quick Connect-_mg_4374-jpg
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: Quick Connect
    No, not really. A diverter valve will not complete the circuit for the PB lines so you run the risk of dead-heading the pump.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Your drawing is showing the function of a single spool standard valve with PB.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Silver Member Andrewnewy's Avatar
    Join Date
    Apr 2011
    Posts
    107
    Australia
    Kioti CS2610
    Default
    You could put in a couple of three way selector valves, this is how they setup front 3 point linkage on tractors, you just have to be berry carefully you turn both valves, otherwise you can dead head the system.
    The other option that might be easier and just as cheap is to just put in a 3 way double acting spool valve. That way you could actually use all 3 at the same to
    Time.
Similar Threads
  1. Hydraulic Quick Connect Won't Connect
    By Tr4824 in forum Hydraulics
    Last Post: 04-14-2017, 11:03 PM
  2. Kubota quick connect question
    By bulldog02 in forum Build-It Yourself
    Last Post: 05-31-2010, 08:00 PM
  3. 3-Point Hitch 7010 Info + 3pt quick connect usage
    By NetworkMD in forum Mahindra Owning/Operating
    Last Post: 08-01-2007, 02:40 PM
  4. Quick connect caps & plugs?
    By Steve_Miller in forum Parts/Repairs
    Last Post: 09-30-2006, 07:45 AM
  5. Major Leak at Quick Connect for FEL
    By Steelfan in forum Parts/Repairs
    Last Post: 10-19-2002, 06:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
