Results 1 to 8 of 8
  1. #1
    Member cytafex's Avatar
    Join Date
    Apr 2011
    Posts
    33
    Clarksburg MA
    Kubota L2950
    Default Kubota LA450 FEL Gland Nut Cracked
    After using my kubota L2950 recently I noticed the seal partially poping out of the cylinder that lifts the loader. I stuffed it back in and it seemed to leak just a bit. The next day I used the loader and noticed not only was it leaking but the gland nut had a crack in it. I took the cylinder to Bacon Sales in Williamsburg MA and they said would be 4-5 days if they had to get parts. It's 2 weeks now and they say they are not able to find a gland nut. Any ideas where to acquire one? Thanks in advance Larry
  2. #2
    Elite Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,886
    Hooksett, NH
    Kubota B2320
    Default Re: Kubota LA450 FEL Gland Nut Cracked
    If it's not avail through kubota, It'll have to be custom machined using ductile iron raw material
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  3. #3
    Join Date
    Apr 2011
    Posts
    33
    Clarksburg MA
    Kubota L2950
    Not virgin material I hope!
  4. #4
    Join Date
    Apr 2011
    Posts
    33
    Clarksburg MA
    Kubota L2950
    Trying to check with kubota...maybe I should try and call?
  5. #5
    Join Date
    Apr 2010
    Posts
    2,886
    Hooksett, NH
    Kubota B2320
    I use MB Tractor up this way......or Chappell, or TownLine Equip.....
    Best to find out part number and start calling.......
    Messicks probably still a better bet.....
  6. #6
    Join Date
    Apr 2010
    Posts
    2,886
    Hooksett, NH
    Kubota B2320
    Yours would look different, but making one is not impossible.....maybe not cost effective for you, but not impossible......
    Attached Thumbnails Attached Thumbnails Kubota LA450 FEL Gland Nut Cracked-008-jpg   Kubota LA450 FEL Gland Nut Cracked-009-jpg
  7. #7
    Join Date
    Apr 2011
    Posts
    33
    Clarksburg MA
    Kubota L2950
    Thanks for the suggestions. Bacon said they may have another cylinder to replace mine as they said parts are not available and will see tomorrow
  8. #8
    Join Date
    Apr 2011
    Posts
    33
    Clarksburg MA
    Kubota L2950
    after 3 weeks and $300 Bacon's Equipment finally came through with a used cylinder for the kubota and I was able to move some wood with it.
Similar Threads
  1. FEL Build for my Kubota B6200
    By GPintheMitten in forum Build-It Yourself
    Last Post: 10-25-2013, 03:15 PM
  2. Kubota L245DT Auxiliary Pump for FEL ?
    By SHINTON in forum Hydraulics
    Last Post: 12-20-2011, 05:36 PM
  3. Can You Defend Kubota Corporation....
    By Junkman in forum Kubota Owning/Operating
    Last Post: 07-16-2010, 03:35 PM
  4. Front-End Loader FEL mounting brackets for Kubota
    By rickstractor in forum Attachments
    Last Post: 01-30-2010, 10:58 AM
  5. Operating Opportunity - Kubota vs Kioti
    By rtimgray in forum Owning/Operating
    Last Post: 12-28-2004, 05:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
