Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jul 2009
    Posts
    14
    East Angus , Quebec, Canada
    kubota L1802DT
    Default PTO pump quick connect
    Hello all!
    Last year I grew tired of the flow given by the hydraulic pump on the tractor so I installed a PTO pump to run the back hoe. I could not figure out a place to install a tank on the tractor itself so I installed a tank on the bh. Not wanting to starve the pump and in a little hurry to enjoy 9 GPM instead of 4.5 I just connected the tank straight to the pump with a 1" suction hose.
    Now, twice this year alone I removed the BH. So I also had to remove the pump. This is a pain since there is no room between the BH and the tractor to pull off the pump. I have to move the tractor a couple inches many times after the BH is off. Also, no room to install longer hoses...
    I have a quick connection on the pressure side and I wonder if there would be something availlable for the suction side. This would allow the pump to be used with other implements I have or planning to get sooner or later.
    in the mean time, if somebody have a good idea on where I could install a 15 gallon tank on a kubota L1802DT (I did'nt know it was a gray market when I purchased) I would be more than happy.
    Zak
    Attached Thumbnails Attached Thumbnails PTO pump quick connect-kubota-l1802dt-jpg
  2. #2
    Epic Contributor
    Join Date
    May 2004
    Posts
    24,105
    Northeast Ohio
    Kubota B2910, Simplicity 18 CFC, Cub Cadet 782
    Default Re: PTO pump quick connect
    Yes there is - pricey, but available:
    Hydraulic Quick Disconnects
    I suspect the problem will be the restriction that any of these impose in the line.
    IOW, a fitting for a 1" (I.D.) hose may have something less than a 1" hole inside, therefore a restriction .... not exactly what one wants on a suction line.
  3. #3
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    behind the seat maybee.ie inbetween the rops, above the toplink area..
    soundguy
  4. #4
    Join Date
    Sep 2010
    Posts
    134
    Eastern Ohio
    (2) IH284Diesels,GE-E8m,GE-E14 Elec-Trac's
    I'd just use a hose-nipple & a camlock of whatever size you want.
    A ball-valve just before the camlock on the hose end for pump would minimize oil loss when disconnecting.
    A standard camlock should be fine....since no pressure on suction line. You already have hose rated as a suction hose I imagine?
  5. #5
    Member
    Join Date
    Dec 2008
    Posts
    49
    Compton, Arkansas
    2350 JD, 820 JD, 3600 Ford
    The tank on mine is under the backhoe and the hoses are long enough I back up close and hook the pump and engage the pto, then back up real close and use the hoe to line up to connect to 3pt.
Similar Threads
  1. Farmhand F11C PTO Pump GPM???
    By oscedo in forum Hydraulics
    Last Post: 02-11-2016, 08:15 PM
  2. external pto pump help
    By aviationben in forum Hydraulics
    Last Post: 11-08-2010, 06:34 PM
  3. Options instead of PRINCE PTO pump
    By dourobob in forum Hydraulics
    Last Post: 01-08-2010, 10:06 AM
  4. PTO hydraulic pump questions
    By jdcoolidge in forum Hydraulics
    Last Post: 07-28-2009, 01:54 PM
  5. PTO Hyd. Pump Specs.?
    By GilaSlim in forum Kubota Owning/Operating
    Last Post: 01-13-2008, 01:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
