Kontak Directional Control Valves
   / Kontak Directional Control Valves #1
William McNett
Sperry Rand New Holland S-14H
Any idea where to find information on Kontak valves in the US?
I've been on that site. They are located somewhere in the UK/England and they don't have any information, only parts if you have part numbers.
Problem being, Kontak Hydraulics became Commercial Hydraulics which is now Parker.
The valve I have is on my Brantly LD6 backhoe that is on the Magntrac MT2016 I bought a few months ago.
I'd really like to find a manual, a source for seals, boots for the joysticks, a pressure relief valve, & a plug to replace the power beyond fitting.
I believe it is a Kontak Unit 10 which became Commercial KA10 which is now a Parker KA10.
http://www.winget.co.uk/document/SERVICE MANUAL KONTAK CONTROL VALVE.pdf
Parker - KA10, 240 BAR (3500 PSI), 55 LPM (15 GPM), SECTIONAL CONSTRUCTION
http://www.hypneu.de/cms/fileadmin/...il/MCD/Catalogs/GENERAL/Mobca_Uk/_4-2KA18.pdf
   / Kontak Directional Control Valves #4
Did you ever find any info on Kontak valves? I'm in the same boat. Parker owns about every hydraulic parts supplier out there but unfortunately their web site is terrible.
Yes there's an older valve and a newer valve
I emailed someone at parker and he put me in touch the someone from parker in europe, he send me some prints and part lists.
The one O-ring I couldn't find in the correct hardness, Parker wanted something like $50 for the 7 I wanted.
I bought a few pieces from White House Products Hydraulic Gear Pumps | White House Products | Hydraulic Pumps in which coming from over the pond was sill cheaper than buying from Parker.
I'll do some searching and see if I can find the docs I have which may be on an old hard drive somewhere around here.
Bill
View attachment KA18-HA300-FCL.pdf
the o-rings between the sections
Parker part = 3460500071 / Dowty Code = 200-019-4490 2 per kit
Parker part = 3460500893 / Dowty Code = 200-020-4490 1 per kit
Parker part = 3460501131 / Dowty Code = 202-518-4490 1 per kit
I don't think I ever found the wiper/seal thats under the cap/around the spool but it's been 4 years :laughing:
KA10/KA18 Spool sealing
Counterbore to take o-ring/ wiper
Kit No. 3469149103 (2x seals/ 2x wipers)
Unit 10/18 Spool Sealing
Groove to take o-ring
Kit No. 3459149003
UNIT 10 MRV (1 1/16 UNEF THREAD)
3459001001 = Pressures between 35 and 100 bar
3459002001 = Pressures between 101 and 275 bar
   / Kontak Directional Control Valves #8
Thanks for all the info. What I'm after is the power beyond fitting for my Kontak valve. My valve has a 3/4 BSP port where the power beyond fitting threads into. Any chance you still have your fitting?
   / Kontak Directional Control Valves #10
