Results 1 to 9 of 9
  1. #1
    Platinum Member dntfxr's Avatar
    Join Date
    Aug 2007
    Posts
    514
    north Louisiana
    Ford, LS
    Default
    I found a good deal on a Koyker 110 loader a guy had on a yanmar 1710. I plan to put it on my kubota b7100. It looks like the subframe will work so my other concern is hydraulics. Can anyone tell me if the valve would be compatible? I read somewhere about the Yanmars and Kubotas using different type hydraulic systems. If it would work where is the best place to tie in the hydraulics? Any help is much appreciated!
    Thanks
    "Even a tuff ol thistle makes a good boot cleaner.."
    LS XR4155C
    Ford 3610
    Ferris is700 61" Vanguard BB
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Help! I need advice on a used loader pleaae...
    I believe your system is open center.
    Do you have a hyd block below your right foot, that has two lines to it and two plugs and a switch. If so, the hoses to your loader valve would go there in place of the two plugs.
    If the loader happens to have a closed center valve, it can be changed out , or maybe an adapter plug would make it an open center valve.
    http://www.tractorbynet.com/forums/a...4-09.17.54.jpg
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Join Date
    Aug 2007
    Posts
    514
    north Louisiana
    Ford, LS
    Default
    Thanks for the help! I found a block there but there appears to be only one plug in it.
    There is also a switch under the seat with what looks like a large plug in the side. Would this be the supply and the single plug on the block a return? Thanks
    Attached Thumbnails Attached Thumbnails Help! I need advice on a used loader pleaae...-image-4016585609-png   Help! I need advice on a used loader pleaae...-image-2850893637-png
    LS XR4155C
    Ford 3610
  4. #4
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    I'm almost sure you well have to get a new plate in picture one. It well have two holes in it and the right side one goes to the loader. Right now oil is passing thru it and the plug is a test port to check pump pressure. I would see a kubota dealer or make one. If you make one it has to have o ring groves cut in it.
  5. #5
    Join Date
    Aug 2007
    Posts
    514
    north Louisiana
    Ford, LS
    Default
    Ok good deal, hopefully the ported block is still available from kubota. I guess the return line would go to the other hole on the block? Or maybe back to the tranny filler hole?
    LS XR4155C
    Ford 3610
  6. #6
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    You can do it that way, but the best way is come off PB port to the other hole and it well feed your 3pt. The out port on the valve goes to tank. Look you trans case over real good, there should be plug some where to get into the trans case. If not the fill plug well work. You also might have to buy a PB plug if the valve well take one.
  7. #7
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    In the first picture, it looks like the front half of the manifold block can be removed and another plate bolted on that will have two outlets and maybe a switch to select flow path.
    The block may look like the one in post #2
    J.J.
    Git er done.
  8. #8
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    dntfxr,
    The block well look just like the cover that is on there now. It uses the same 4 bolts that's in there right now, it could come with 3 holes if you get it from kubota, if it does just plug it. Your block only has a in and out lines.
  9. #9
    Join Date
    Aug 2007
    Posts
    514
    north Louisiana
    Ford, LS
    Default
    Allright, Thanks for all the help guys. Glad to have some smart friends here! Now I need to decide if I'm gonna pull the trigger on this loader or just put the coin toward my next tractor...
    LS XR4155C
    Ford 3610
Similar Threads
  1. Your 4210 4310...LOADER USE NOT APPROVED BY DEERE
    By del in forum John Deere Owning/Operating
    Last Post: 05-26-2010, 06:50 PM
  2. Buying Advice Advice on a loader for jm224
    By jaroban in forum Chinese Tractors
    Last Post: 09-18-2006, 05:42 PM
  3. 4200 loader advice
    By Deere Man in forum John Deere Owning/Operating
    Last Post: 09-05-2006, 08:46 AM
  4. Need Ford Loader and Brake Advice
    By herdfan in forum Ford Vintage Tractors
    Last Post: 02-14-2004, 12:18 AM
  5. 70A loader vs. 52 model
    By fancsco in forum John Deere Buying/Pricing
    Last Post: 12-07-2001, 05:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
