Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
  1. #21
    Join Date
    Sep 2010
    Posts
    134
    Eastern Ohio
    (2) IH284Diesels,GE-E8m,GE-E14 Elec-Trac's
    Default Re: Repairing metal hydraulic line
    maybe you can ask the guy with the leak what he has nearby?
    I hope he gets it silver-soldered, myself.
    over & out
  2. #22
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    personally that's what i would do.. IE.. silver solder it myself. easie rthan cut and union.. faster too.
    soundguy
  3. #23
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Swagelock is one brand in particular that is pressure rated. The tube may be metric-it will have to be accurately measured.
    Soldering/Brazing may work, but the line must be removed to do it with any chance of success IMO. Since you have to go through all that work to remove it, solder it, then re-install to test it...You should price a new line.
    Which line is it? Part #25 is only $50.59. Hardly worth trying to fix it for that.
    Part Details
    Part Number:AM101979
    Part Price: 50.59 USD
    On Hand: 0 Check Other Stores
    Description: LINE, OIL
    Attached Thumbnails Attached Thumbnails Repairing metal hydraulic line-755-gif
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #24
    Join Date
    Oct 2008
    Posts
    1,071
    Piedmont Triad, NC
    Didn't intend to have a Deere fleet - it just happened 310C, F915,102 & 5200
    Kenny has hit the mark on this repair. I was going to suggest a custom hydraulic hose. Instead of a metal line, my Deere dealer made me a hose with the same ends. Saved $100 for me after $35 for the hose.
    I too, have used Swagelok fittings on High pressure industrial process lines(10,000 psi working pressure) Not cheap but they did the job. perhaps the break is small enough to be cut out and then rejoined with a tube union. But at best you'd only be saving a few dollars.
    Buy the correct part.
  5. #25
    Member
    Join Date
    Jun 2009
    Posts
    26
    WV highlands
    John Deere 755 mfwd JD 450B Crawler Dozer
    Quote Originally Posted by kennyd View Post
    Part Details
    Thanks Kenny. It is either part number 20 or 25 on the diagram. I wont be sure until I get back out there and can look underneigth at it again. There are two lines that run next to each other right above the drive shaft that connects to the mfwd. It is the left side line.
    It was devil's butt hot this past weekend and I didn't feel like tracing the line out to each end after I removed the belly mower.
    I would definetly rather replace the line if the cost is only under $100.00
    Do you know the procedure for bleeding the lines once they are reconnected?
  6. #26
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    depending on what it feeds, just leave one end .. the far end, a lil loose and power up till it stops bubbling and striaght oil comes out... shut down and tighten.. then run that function thru it's paces.. ie.. steering or hyds or if hst, then it will auto bleed out. then check sump too for oil loss.. etc.
    soundguy
  7. #27
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,838
    Nova Scotia, Canada
    If the new part is fifty bucks the Swedgelock fittings for repair will probably cost quite a bit more.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  8. #28
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    Quote Originally Posted by Egon View Post
    i don't know what swedgelocks cost.. but the 1/4" 9000 psi union I mentioned costs 2.67$.. shipping likely costs 5$ for ups.. so call it 8$ for the hi pressure compression union repair... and the downtime.. etc.
    i myself would very likely silver solder a patch on it..
    soundguy
  9. #29
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    It is a Open Center Hydraulic system, no "bleeding" is needed. Just start it up and cycle all the controls. Then re-check fluid level.
    KennyD
    www.boltonhooks.com
  10. #30
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    If the line you are replacing is your feed line, then you don't need to cycle anything.
    Once you start the engine, the pump is already pushing fluid through the lines and valves at the GPM rate of your pump, and on the tank/reservoir.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
Similar Threads
  1. Leaking Hydraulic Line - Same Repair 3 Times
    By cboudreau in forum Kubota Owning/Operating
    Last Post: 06-05-2012, 04:33 PM
  2. Hydraulic return line question.
    By gemini5362 in forum Hydraulics
    Last Post: 12-18-2007, 09:27 PM
  3. Replacement Hydraulic Line Dust Caps
    By Mike5252 in forum Attachments
    Last Post: 07-21-2006, 01:40 AM
  4. IH3200B losing hydraulic fluid from breather
    By 5030tinkerer in forum Hydraulics
    Last Post: 01-28-2006, 11:22 PM
  5. Hydraulic cylinder & line leaks
    By Chris in forum Kubota Owning/Operating
    Last Post: 04-14-2000, 05:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
