Page 2 of 13 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 124
  1. #11
    Join Date
    Feb 2009
    Posts
    1,061
    CA
    2002 New Holland TC40S
    Default Re: Adding Rear remotes
    Quote Originally Posted by glukowicz View Post
    I have been reading all the many ways of adding these rear remotes to a tractor. I want to add one to operate a scrape blade to angle and tilt it. My dealer sells a kit for my tractor, a branson, for a single spool for $750, Ouch! In talking further with him he asked, " Do you use your FEL when using the blade?" i said not usually. He said a simple way to accomplish this would be to run more lines from the FEL joystick to the rear with QD's and just disconnect the FEL and connect the new hoses that will control the blade. Now the joystick will control the rear blade. Do you guys see a problem with this if I can live w/o the FEL when using the blade. If really needed I could reattach the FEL.
    Thanks in advance for any ideas.
    I'm assuming that you have one rear remote set at this time. To operate a TnT you need two sets of RRs, is that $750.00 an installed price for one set of RRs? You might be able to do the install yourself-website the parts kits and the install instructions to see if you can. My NH TC40S for two sets of rear remotes ran about $520.00 per set and I installed them-easy job although one rear tire needed to be removed.
    If you go this way, other things can be powered off of those QDs-FEL grapple, Wood splitter, down force PHD, York rake, tree saw, etc.
  2. #12
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    I do not have any rear remotes other than the 3 pt hitch. T[U]he $750 was for a single set of remotes w/o installation and 950 for two. I talked with someone at Surplus that says I can add 2 double selector valves between he joystick and the FEL and the new rear remote hoses and either manually, if using manual selector switches, or with a toggle switch, if electrical, to switch flow between the FEL and the new rear remotes.
    When I look at the valves it seems that will work. It would bring down the cost quite a bit and I would be able to use the one joystick to operate both. And with a flick of a switch change back and forth between FEL and scrape blade.
  3. #13
    Bronze Member DJNebraska's Avatar
    Join Date
    Jul 2011
    Posts
    53
    Ohiowa, NE
    Deere 4010
    glukowicz,
    Take a look at this link. I think it's what you're looking for.
    SelectPLUS 12 GPM Selector/Diverter Valve
  4. #14
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    Yes this would work, I think. I would need two of them to operate 2 cylinders and then the cost is up there again. If this does work, I can get 2 double selenoid selector valves, each costing $150, and a good switch which is 1/2 the cost of this kit, again I think.
  5. #15
    Join Date
    Jun 2011
    Posts
    50
    Litchfield County. CT
    Mf2610tlb
    Glukowicz,
    No problem lifting the FEL. Using the bucket curl on the joystick to lift and lower the rotary cutter.
  6. #16
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    True, however, if you want to angle and tilt a scrape blade, you need all controls of the FEL.
  7. #17
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    I believe I would interrupt the supply fluid for the 3pt, and feed the new two lever valve like this. Just run the OUT port from the new valve to tank.
    Surplus Center - 2 SPOOL 10 GPM PRINCE LVT1GB5AC1-26 OC VALVE
    http://www.surpluscenter.com/item.as...name=hydraulic
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  8. #18
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    I take it that this valve would be mounted next to the seat and one lever would control the tilt and the other would control the angle. The 3 pt hitch valve would need to have a power beyond valve also, correct? I would also still be able to use the 3 pt hitch to lift the blade?
  9. #19
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Yes for the PB, and yes to operating the 3pt.
    You can add as many spools as you need on the valve .
    This valve would also work for tilt and angle, and has PB.
    http://www.surpluscenter.com/Instruct/I9-7401.pdf
    3pt valve is last valve in series, and does not need a PB. The fluid from the 3pt, just dumps into the tank
    J.J.
    Git er done.
  10. #20
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    Thanks, JJ! I take it from your photo, that you used to live in a colder climate than Jacksonville? That jacket looks pretty heavy!
    I will repost after I get it all worked out. I should be done definitely by 2013!
Similar Threads
  1. How Many Rear Remotes?
    By hunterridgefarm in forum Owning/Operating
    Last Post: 04-09-2012, 09:30 PM
  2. Replies: 13
    Last Post: 03-16-2010, 12:35 PM
  3. Adding rear remotes to a 2620
    By TRUST in forum Kubota Owning/Operating
    Last Post: 01-05-2009, 10:21 PM
  4. Grapples, remotes and snow blowers...
    By buyerjohn in forum Kioti Buying/Pricing
    Last Post: 09-07-2006, 01:16 PM
  5. Adding rear remotes to 855
    By FreakDaddy in forum John Deere Owning/Operating
    Last Post: 04-27-2006, 09:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
