Page 3 of 13 FirstFirst 123456 ... LastLast
Results 21 to 30 of 126
  1. #21
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Adding Rear remotes
    I would go ahead and draw out the hyd from the pump to the 3pt. Then if you need to interrupt a hyd line to add another valve, you will know where to cut the line or just re-route the supply. Keep in mind, that all valves should be in series.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  2. #22
    Join Date
    Aug 2004
    Posts
    1,945
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    Lately I have been finding better deals at Bailey's than at Surplus Center.
    Directional Control Valves 220-907 Detailed Information
    Hydraulic Cylinder Components, Products
    If your Branson 3820I is rated at 8.4gpm, a 10gpm valve will give you better control than one rated for higher flow.
    Just to add to JJ's good advice, the hydraulic supply loop likely goes from pump to loader valve to 3ph valve which is mounted directly to the hydraulic reservoir. The port on the loader valve that is connected to the 3ph valve is called a Power Beyond port. The loader valve should also have a low pressure return line going directly to the reservoir. The return port is typically labelled "out." Get a control valve set up for power beyond, route the flow from the loader power beyond port to the "in" port on the new valve, route flow from the power beyond port on the new valve to the 3ph valve, and tee the low pressure return flow from the new valve into the return flow from the loader valve. You can get low pressure hose for the return lines but high pressure hose is easier to find and cheaper in my experience.
    If you order a valve from Surplus Center or Baileys, check out the current fittings in your system, do a sketch like JJ says, and note the fitting types and hose lengths. You can order fittings and hoses along with the valve. I personally like to use the stock hoses with nptf fittings and buy adapters as needed.
    Brad
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  3. #23
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    My Branson is a 3820 and the hydraulics are 6.9. I like JJ's idea better than the one I had. I need just the mount for the valve made and mounted on the ROPS. All the hydraulic lines will be shorter and it will be a cleaner application since it is nearer to the rear of the tractor. I am letting the dealer get me a price for the factory rear remotes bracket. I am going to go to a local hydraulics supply for my hoses and fittings, since I don' t seem to understand the different types. It will become clearer after I buy what I need for the job.
  4. #24
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,408
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Quote Originally Posted by glukowicz View Post
    I have been reading all the many ways of adding these rear remotes to a tractor. I want to add one to operate a scrape blade to angle and tilt it. My dealer sells a kit for my tractor, a branson, for a single spool for $750, Ouch! In talking further with him he asked, " Do you use your FEL when using the blade?" i said not usually. He said a simple way to accomplish this would be to run more lines from the FEL joystick to the rear with QD's and just disconnect the FEL and connect the new hoses that will control the blade. Now the joystick will control the rear blade. Do you guys see a problem with this if I can live w/o the FEL when using the blade. If really needed I could reattach the FEL.
    Thanks in advance for any ideas.
    Here's the triple remote setup on my 2008 Mahindra 5525. Dealer installed when I bought the tractor new--$750 parts and labor.
    Adding Rear remotes-dscf0066-small-jpgAdding Rear remotes-dscf0067-small-jpg
    Pressure comes from the power beyond port on the FEL control valve. IIRC you have to insert a sleeve in the PB port when using it for remotes.
    Adding Rear remotes-dscf0138-small-jpg
    Adding Rear remotes-dscf0137-small-jpg
    Adding Rear remotes-dscf0208-small-jpg
    The return from the remotes is teed into the low pressure line from the FEL valve.
    Hope this helps.
    Good luck
  5. #25
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    Nice job, Flusher. Have you found that mounting to the fender id stable enough?
  6. #26
    Join Date
    Jun 2005
    Posts
    7,408
    Sacramento
    No problem--Mahindra uses real steel in their tractors, not thin sheet metal or (gasp) plastic, so those hydraulic parts are tied down solidly.
  7. #27
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    Mine is fairly solid also. I think yours is the first one I have ever seen mounted on the fender.
  8. #28
    Join Date
    Jun 2005
    Posts
    7,408
    Sacramento
    It helps a lot to have that large flat top fender on my Mahindra so there's plenty of room for the hydraulic stuff.
  9. #29
    Join Date
    Aug 2011
    Posts
    52
    06 Branson 3820i
    Do you remember where you bought your valve from? And was the remote bracket made for you or did you buy it somewhere?
  10. #30
    Join Date
    Jun 2005
    Posts
    7,408
    Sacramento
    My dealer, Dave's Tractor in Red Bluff, CA, bought the parts and made all the sheet metal parts.
    Dave is a TBN member and reguiarly posts here. His handle is "DavesTractor". You can send him a PM on this website or contact him on his website
    Dave's Tractor, Inc - Home
    The triple remote valve is made by Dinoil, a European company. Haven't been able to find a U.S. distributor yet.
Similar Threads
  1. How Many Rear Remotes?
    By hunterridgefarm in forum Owning/Operating
    Last Post: 04-09-2012, 08:30 PM
  2. Replies: 13
    Last Post: 03-16-2010, 11:35 AM
  3. Adding rear remotes to a 2620
    By TRUST in forum Kubota Owning/Operating
    Last Post: 01-05-2009, 09:21 PM
  4. Grapples, remotes and snow blowers...
    By buyerjohn in forum Kioti Buying/Pricing
    Last Post: 09-07-2006, 12:16 PM
  5. Adding rear remotes to 855
    By FreakDaddy in forum John Deere Owning/Operating
    Last Post: 04-27-2006, 08:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
