MossflowerWoods
Super Member
- Joined
- Aug 12, 2011
- Messages
- 6,067
- Location
- Fredericksburg, VA
- Tractor
- Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
David, maybe cause you thought why replace the whole hose when you just need a new fitting and as long as you have enough length(the new fitting will shorten it up some although putting 90's in will give a little of that back). You might want to do one 90 and one 45 so you route them together or at least add a short nipple to one so you can route them side by side.
One of the things I was not impressed with as I got into tractoring was the lack of protection they gave hydraulic hoses. I have put rubberwrap (strips of old tire innertube) and chafing gear (old fire hose works great) in several places on mine.
We always keep a bunch of the old style clamp together fittings on the boat so we can quickly repair a hose and keep on fishing.
Rick,
Agreed, not enough protection of the hyd connectors...
I think there is slack at the other end, and this is the fixed length side, the other side (on the grapple itself) has a wide range of motion...
I'm going to do both. I'm going to get a new hose, and I'm going to crimp a new connector on also. Double back-up...
David
