Results 1 to 7 of 7
  1. #1
    Join Date
    Sep 2008
    Posts
    533
    North East TX
    Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
    Default Wanted - Good design for home made hydraulic shop press.
    I recently acquired a couple of American Made 30 ton Bottle Jacks. I was thinking that I would use one as the heart of a shop press, because I have needed one on several occasions and have never had one at my disposal. If anyone has any really good designs for a home made, general purpose, heavy duty shop press I would really like to see them. Please keep in mind that the more versatile and adaptable to various applications the better. thanks
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Wanted - Good design for home made hydraulic shop press.
    You might get some good ideas from this web site.
    Handy Bend | Shop Outfitters
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Join Date
    Sep 2008
    Posts
    533
    North East TX
    The jack Im planning to use has a stroke of 7". Is this adequate for most jobs that one would use a press for? Also, are there specific dimensions that I should make sure and ahdere to. For instance, How far from the floor should the bottom of the press be in order to work on "most" axles, drive shafts, etc.? I need to here from those of you who use such a press pretty often. I want this to be a one time build with no major modifications necessary just because I didn't do my research. thanks
  4. #4
    Silver Member BigBoyinMS's Avatar
    Join Date
    Nov 2005
    Posts
    242
    Central Mississippi
    '73 MF135 & Montana 4540
    Just a thought... why not go by your local Harbor Freight and take some measurements? It's cheap stuff but the size seems to work for the shops I've seen them in.
    They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety.
    Ben Franklin
    1973 MF135 Perkins Gas and 2006 Montana 4540 w/FEL
  5. #5
    Gold Member
    Join Date
    Sep 2010
    Posts
    296
    Midcoast Maine
    Yanmar YM186D
    Quote Originally Posted by BigBoyinMS View Post
    +1...you know the stuff they're selling at HF is the cheapest/lightest they can get by with for the tonnage. Go measure a 30 tonner and don't build anything less. I'm relatively inexperienced with my 30 ton and it has scared the ***** out of me a few times, the last thing I want to worry about is the press itself coming apart. 60000 lbs is a lot!!!
  6. #6
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,387
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Here is just one of the things I got going on right now. 2 many hands in the fire right now. But anyways I took the jack off and put this cyl and valve on mine. I'm going to use my tractor right now and see how that works out.
    Attached Thumbnails Attached Thumbnails Wanted - Good design for home made hydraulic shop press.-img_1076a-jpg
  7. #7
    Elite Member sandman2234's Avatar
    Join Date
    Dec 2005
    Posts
    4,450
    Jacksonville, Florida
    JD2555 and a few Allis Chalmers and now one Kubota
    Quote Originally Posted by pharmvet View Post
    Just make sure the base has has pin holes that are less than 7 inches apart and you should be ok. Six ought to be a good distance.
    David from jax
    A serious accident is one that money won't fix.
Similar Threads
  1. Good day at the pawn shop
    By emmy71 in forum Projects
    Last Post: 11-12-2008, 12:46 PM
  2. Help me design a leaf-collection bucket!
    By davesisk in forum Build-It Yourself
    Last Post: 06-30-2005, 01:16 AM
  3. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 11:56 AM
  4. Chain of command
    Last Post: 04-13-2002, 07:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
