flingwing1969
- Joined
- Jun 2, 2008
- Messages
- 692
- Tractor
- LS G3038, JD GT275, and Bolins H16
Anyone. The float detent in my B21's boom control valve has never worked (used tractor purchase) - it is supposed to lock when the lever is snapped all the way forward but it does not. The float works fine as long as I hold the lever forward but this is simply unworkable for any road work - I do a fair amount of back dragging with my FEL but it work oh so much better if I could put it into float and have it stay there.
I know the detent balls, or some part of that system is gummed up, the question is, do I have to pull the whole otherwise perfectly functioning valve and do a complete disassembly/reassembly (new o-rings etc) or can I simply pull off the bottom cap to get to the detent assembly? The page from my factory manual is attached.
