I didnt like how the factory rear hyd valve from Kubota was supposed to be mounted on the ROPS for the Kubota B2920. After mounting on the rops, it blocks a significant amount of viewing angle and every time that I was using the 3pt or 4wd, my elbow would hit. Also, if the fittings ever leak - they drip right onto the fender and to the light (a very poor design in my opinion - but probably very cheap as it is universal)
The mount is made out of 3/8" steel welded 2 pieces together to match the angle of the rops on the inside of the fender, then parallel to the fender for the valve mounting plate. Once I had the valve mounted and it all clearing the 3pt and fender - I custom made the handle to come up through the blank panel on the fender so the lever was in a common location and easy to manipulate.
Since I had all of the stock lines that came with the valve, I simply had them shortened to the lengths that I needed and then installed the ends on them. I only spent ~$60 in additional fittings and everything else I had laying around. The extra length that I had also worked out just right for the hoses for the Hyd top link that is also installed.
I also added a hyd top link as can be seen in the pictures and video's.
Kubota B2920 Hyd Top Link.wmv - YouTube
