Results 1 to 4 of 4
  1. #1
    Join Date
    Jan 2002
    Posts
    1,569
    Colorado
    2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
    Default Balloon trick for protecting hydraulic fittings
    Here's a cheap easy method of keeping the dirt, dust and moisture out of hydraulic hose connections. I got some balloons and cut the last 1/2" or so off the end, so it has a hole at both ends. Before I hook the hydraulic line to the tractor, I put the balloon over it and fold it back out of the way (the balloon on the top fitting in the picture is still folded back). Then I hook up the line and stretch the balloon back over the fitting (the balloon on the bottom fitting in the picture is stretched back over the fitting). It does a great job of keeping dirt and moisture out of the fitting, and catches any seepage.
    Attached Images Attached Images
  2. #2
    Join Date
    Dec 2002
    Posts
    306
    Magnolia, TX
    99 JD4200 4WD Collarshift
    Default Re: Balloon trick for protecting hydraulic fittings
    Cool. I wonder if an old bike inner tube would work. I'll try it sometime.
  3. #3
    Join Date
    Jan 2002
    Posts
    1,569
    Colorado
    </font><font color="blue" class="small">( I wonder if an old bike inner tube would work.)</font>
    That's a good idea! It would be thicker, so it would last longer and hold up better to pressure washing. The balloons will deteriorate after a while and have to be replaced.
  4. #4
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Bicycle inner tubes work great as long as you get a slightly larger diameter than what you need to cover. You would think that they would stretch, but it is difficult to do so. Several months ago I installed a section of bicycle inner tube over the main wiring connector under the tractor and wire tied the ends of the inner tube tight. First I applied an electrical contact preservative to the connector's pins and sockets. I figured that the connector would probably get wet and muddy many times over the life of the tractor and that the protection could eliminate electrical trouble shooting down the road.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
