Results 1 to 8 of 8
  1. #1
    Join Date
    Mar 2007
    Posts
    106
    Default Single acting cylinders ?
    I'm pretty sure this has been covered. I searched and searched but couldn't find my answer.
    I'm putting a Meyers Snowplow on my Kioti. In the past I had a smaller blade mounted up front. On that blade I fabricated most everything. I used 2 D.A. cylinders one for up down the other for angle. Running through the loader joystick. Ran this for 2 years. The blade is just too short. So heres my question. Can I just use the right left lines to the S.A. cylinders? My understanding of this setup is the pressure will go through the relief valve on the oppissite side of which I am angling the plow. Is this safe? Any long term side effects on the relief? Thanks for the input!
    Mitch Hall
    Live in Big Blue Country (GO CATS)
    My toy: 2006 CK20HST, FEL, Rears loaded, 4'BB, 4' cutter, bunches of suff I made.
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Single acting cylinders ?
    are you trying to connect 2 sa cy;s in place of 1 da, using 1 dual spool?
  3. #3
    Join Date
    Mar 2007
    Posts
    106
    Quote Originally Posted by Soundguy View Post
    Not sure what a dual spool is.... I'm wanting to know if I can hook up the line for the curl on the loader to one SA cylinder & the dump on the loader to another SA cylinder to angle the snowplow... Guess I'll be going to google now to see what a dual spool valve is....
    Mitch Hall
  4. #4
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    A dual spool valve will simply control two separate flow paths.
    Single spool, one path.
    Three spool valve , three paths, etc.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  5. #5
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,254
    Central Ohio
    Kubota MX5100
    Yes, connecting it like that should work just fine
    The way you have your two SA cylinders hooked up is almost the same as a single DA cylinder, except the SA cylinders have equal volumes.
    When you angle the plow, it will force the fliud out of the other cylinder. Just like when using a function on your loader, it forces fluid out of the other side of the cylinder and back to the talk. You are just taking THAT volume of fluid and using it in a seperate cylinder, if that makes sense.
    But....You may want to think about using a crossover valve. Because if you are angled and catch something with the leading edge of the blade, it tries really hard to collapse that cylinder. And there is no relief for it unless you add the crossover. Without it, it isnt hard to blow lines off the cylinders
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  6. #6
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,104
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by J_J View Post
    I believe he was referring to 1 dual acting spool (4-way) as opposed to 1 single acting spool (3-way).
  7. #7
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    Quote Originally Posted by Bigboyskioti View Post
    That's what I do, works great.
    Someone in another thread mentioned that it's better than just one DA cylinder, because the plow is better suported, backed by cylinders on each side ??
    JB
    Attached Thumbnails Attached Thumbnails Single acting cylinders ?-dsc01126-jpg
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  8. #8
    Join Date
    Mar 2007
    Posts
    106
    Thanks for all the respones... I thought It would work, just wanted to make sure.I'm going to try it. I've just about waited to long to set this up. It's going to knock some time off on fabrication to use the Singles. Thanks again.
    Mitch Hall
Similar Threads
  1. single acting cylinder and remotes
    By hydrogeo in forum Build-It Yourself
    Last Post: 11-27-2011, 05:06 PM
  2. Finally Building my Backhoe
    By Iplayfarmer in forum Build-It Yourself
    Last Post: 06-03-2011, 04:38 PM
  3. single acting hydraulic cylinders
    By Blackfoot in forum Hydraulics
    Last Post: 10-20-2008, 09:45 PM
  4. single acting toplink hookup
    By ToddDale in forum Hydraulics
    Last Post: 09-20-2008, 07:30 PM
  5. single acting vs. double acting
    By bmw63 in forum Hydraulics
    Last Post: 06-15-2007, 08:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
