question about hydraulic valves
   / question about hydraulic valves #11
WilcoKubota; said:
Its for a FEL, so only if they have a PB port i can connect it like this:
Wilco.
Look at the schematic at the bottom. The flow has to go through the valve and then go to another valve IN port.
http://www.surpluscenter.com/Instruct/I9- 7863.pdf
Do you need float or regen?
I don't get it very much, but i've seen the prices of a single spool valve with PB port, and i can better buy a 3 spool valve because that is cheaper.
Thank you for the help anyway.
Wilco.
   / question about hydraulic valves #13
That is fine, but if you have a 3pt on the tractor, you will need PB on that three spool valve.
If that is the only valve you will use, it does not have to be PB.
   / question about hydraulic valves #15
Yes, that is your supply for the 3pt valve and the 3pt dumps to tank. The OUT port of the FEL valve should go to tank.
Do you need any more hyd for the rear such as a remote valve for implements, etc?
Ok. I understand.
I already have one double action valve at the back. i think I've got a picture of it..
you can see it between the wheel and the top link, at the 1th picture.
I want to make the valve above the brake shield (I don't know the correct name.), at the 2nd picture.
Wilco
   / question about hydraulic valves #17
Can you provide a description of the hyd flow as it is now.
A basic tractor comes with a 3pt, so the pump flow only goes to the 3pt. It may do this through a hyd block at the middle of the tractor, or direct. You may also have a switch to switch the flow from 3pt to something else.
You said something about a valve. I only see two lines that are capped. Is there a valve for those lines?
I have a Kubota B9200 HST, and the pump flow goes through a hyd block and to the 3pt in one position of a switch, and if I switch the flow, it goes to a rear remote first and then to the 3pt. If I am not using the rear remote, I plug the two hoses together.
No, its a built in valve, the lines at the picture are to a quick male connector. I'ts an old picture because i have now female connectors on it.
Wilco
   / question about hydraulic valves #19
We were talking about the rubber pipe going to the left from the hydro cylinder area just under the seat.
I have it this way:
Wilco
2023 John Deere HD50F Draper Head (A53342)
2023 John Deere...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
2014 AMADAS SPC-6-36 LOT NUMBER 211 (A53084)
2014 AMADAS...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53472)
2022 New Holland...
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X8JD476306 (A51572)
2018 Peterbilt 389...
