Results 1 to 7 of 7
  1. #1
    Join Date
    Jul 2011
    Posts
    128
    AGCO/CAT Challenger MT275
    Default ML30 Loader MT275 Challenger tractor increase loader power
    How do I or can I increase the power in my hydraulics. I understand (and I know its not on all tractors and I'm not sure if mine is one of them) but I hear there is an adjuster screw to in crease hydraulic pressure. Which I know I'll get a pressure gauge and find out what the max pressure is and set it up to the max pressure. Thanks
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: ML30 Loader MT275 Challenger tractor increase loader power
    If you know the pumps rated pressure, you can install a hyd gage and check and set the hyd pressure. It should be about 50 to 100 below the pump max pressure.
    You can install a gage permanently in the IN port of the FEL valve, or use the plug in test hyd gages kits.
    You can also plug the gage into a QD and momentary flip the lever to get a reading and or to set the pressure.
    Here are some examples of a hyd gage test kits.
    Larger hyd cyl will also provide more power.
    Attached Thumbnails Attached Thumbnails ML30 Loader MT275 Challenger tractor increase loader power-hyd-gage-qd-jpg
    Attached Images Attached Images
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Join Date
    Jul 2011
    Posts
    128
    I like the installing the gauge. How and where do you install it? Does any one have any pics of theirs installed?
    How do I increase it once I get the gauge installed?
  4. #4
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    You either turn a screw on the relief valve or add shims to the relief valve. Look at the parts for your valve and determine what you have and go from there. If it is adjustable, install the gage and adjust. If you have to add shims, take the model number of the valve, or part numbers and purchase the shims at your dealer
    If you want to install the gage, then you add a tee to the IN port of the FEL valve and add a 3000 psi gage in the tee. Then you can monitor and trouble shoot the hyd system.
    It will show the hyd pressure for any operation you are doing.
    J.J.
    Git er done.
  5. #5
    New Member
    Join Date
    Jun 2016
    Posts
    2
    sharon
    Challenger MT265
    I have a similar problem, my ML30 bucket is stuck in the full up position! I have been online trying to find a schematic that might address this issue but so far nothing. I need the parts/service manual for the ML30.
  6. #6
    Silver Member aircommuter's Avatar
    Join Date
    Nov 2012
    Posts
    175
    coulterville,ca
    case 570lxt, JCB 1550B, Gradall 534c, Hyster C612B,Ford 445A
    You want to look in a manual and see what the system pressure should be set at. The pumps are capable of far more than most systems could handle. Install the gauge in a main pressure test port or the loader lift line and read the gauge when the loader is at the top and won't go any higher. Then adjust the pressure relief valve to the specified amount. The manual will also show the pressure regulator location.
  7. #7
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,179
    SouthEast Michigan
    Massey 1652 HST Cab
    http://www.tractorbynet.com/forums/s...d.php?t=329088
    In case you weren't aware, the Challenger, AGCO, and Massey units all roll off the same assembly from Iseki in Japan. Your Massey equivalent would be the MF1540. That's the previous generation to my Massey machines, but the relief system is likely still the same. So... I can't guarantee compatibility of course, but that thread should direct you appropriately.
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
Similar Threads
  1. Goodbye Kubota, Hello Power Trac
    By MChalkley in forum Power Trac
    Last Post: Yesterday, 11:10 AM
  2. Ballast Ballast
    By JDGREEN4ME in forum John Deere Owning/Operating
    Last Post: 10-17-2002, 11:21 PM
  3. 110
    By joecdeere in forum John Deere Buying/Pricing
    Last Post: 05-08-2002, 10:34 PM
  4. 70A loader vs. 52 model
    By fancsco in forum John Deere Buying/Pricing
    Last Post: 12-07-2001, 06:10 PM
  5. Replies: 92
    Last Post: 08-21-2001, 12:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
