J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,928
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
I was simply trying to talk you into a regular loader valve with float and poss regen. Sure, the new valve will work. It just will not have float.
A good many people use float quite a bit.
There is a way to get float on the lift arms, and that is by adding this small valve to the lift circuit.
http://www.surpluscenter.com/item.asp?item=9-7899&catname=hydraulic
Connection would be similar to this.
http://www.surpluscenter.com/Drawing/DR9-1064.pdf
