Results 1 to 10 of 11
02-28-2012, 11:40 AM #1Member
- Join Date
- Jan 2008
- Posts
- 33
- Location
- hollis nh
hydraulic seal replacement
i got a seal kit for a dump cylinder that leaks. are these things easy to work on.bill
02-28-2012, 12:05 PM #2Silver Member
- Join Date
- Sep 2007
- Posts
- 129
- Location
- Mason Dixon Line
- Tractor
- Kubota L2350, Bolens / Iseki 154G, old IH Cub Cadets - 1250, 105, 124
Re: hydraulic seal replacement
Easy is a relative term.....many variables of design, age, conditions of the equipment along with considerations of available tools / abilities can make a huge difference between easy and hard.
Pictures would help make some judgement on the issue.
02-28-2012, 07:01 PM #3
http://youtu.be/3YmMNpbFjp0 ..........Sure, everything's easy.....
2010 Kubota B2320 FEL & BH65
If it ain't fixed don't broke it!
http://www.tractorbynet.com/content/...-month-wdchyd/
03-01-2012, 10:27 AM #4Member
- Join Date
- Jan 2008
- Posts
- 33
- Location
- hollis nh
03-01-2012, 12:30 PM #5
Those are pretty straight-froward......look to see if there is a rust ring where the seal sits when travelling down the road.....it's common for a ring to form from grit getting under the wiper and wearing it out (then you need a hyd rod made up)
If that chrome rod is good then you're good to go, just yank, disassemble, polish, clean, lubricate and reassemble
be carefull not to ding the rod with hammers when removing upper crosshead..
03-13-2012, 04:25 PM #6Member
- Join Date
- Jan 2008
- Posts
- 33
- Location
- hollis nh
got the seals changed out .just takes alittle patients.no more leaks. bill
03-13-2012, 04:31 PM #7Member
- Join Date
- Jan 2008
- Posts
- 33
- Location
- hollis nh
this is what it looks like inside.bill
03-13-2012, 07:22 PM #82010 Kubota B2320 FEL & BH65
03-13-2012, 07:25 PM #9
03-15-2012, 11:57 AM #10Member
- Join Date
- Jan 2008
- Posts
- 33
- Location
- hollis nh
i used 1\4 inch rubber myself.b
Similar Threads
Trunion shaft seal replacement
By MFP8055 in forum Cub Cadet L&GReplies: 3Last Post: 05-17-2011, 09:28 AM -
hydraulic hose replacement
By jpat34721 in forum Parts/RepairsReplies: 5Last Post: 03-02-2011, 08:47 PM -
Tiller Woods Tiller Oil Seal Replacement
By AGSAVL in forum AttachmentsReplies: 4Last Post: 04-18-2010, 10:43 PM -
Hydraulic Cooler Unit Replacement
By CBB in forum Kioti Owning/OperatingReplies: 3Last Post: 02-25-2007, 05:45 PM -
Hydraulic remotes vs hydraulic PTO?
By davesisk in forum HydraulicsReplies: 6Last Post: 10-23-2002, 08:35 PM
