Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Apr 2011
    Posts
    24
    Mahindra 3215 HST
    Default Parker H series pump question
    I picked up a Parker H series pump for a project. It has a built-in relief valve and flow divider. I was wondering if anyone had experience with this model? If I read the spec.'s correctly, I believe I can leave the secondary port and relief port blocked if not needed? *NOTE: ''D'' Circuit: Relief valve flow and flow divider secondary flow return to pump inlet internally - primarily used in ''on-road'' equipment power steering.
    I am not familiar with this style pump and don't want to blow it apart.
    Attached Thumbnails Attached Thumbnails Parker H series pump question-img010.jpg
    Mahindra 3215HST
    Kubota B7100HST
    Belarus 250AS
    Belarus 572
    Custom Bandmill (under construction)
    International 500 Dozer w/ 6-way blade
    various attachments and toys...
  2. #2
    Join Date
    Jan 2010
    Posts
    1,875
    Northern, IL
    Branson 2400H
    Default Re: Parker H series pump question
    Do not block the secondary port unless there is an internal passage between this port and the pump inlet. Blocking this port with no internal connection will destroy the pump.
    Roy
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD 112
    BX1850 gone but not forgotten
  3. #3
    New Member
    Join Date
    Apr 2011
    Posts
    24
    Mahindra 3215 HST
    That was my concern and wanted a 'double check' on the Note "D", which indicates that it does return to inlet internally.
    Mahindra 3215HST
    Kubota B7100HST
    Belarus 250AS
    Belarus 572
Similar Threads
  1. s650G accelerator pump question
    By hawks000 in forum Mitsubishi/Satoh
    Last Post: 10-15-2011, 02:20 PM
  2. John Deere 300B hyd. pump question
    By Jallcorn in forum Hydraulics
    Last Post: 08-12-2011, 03:07 PM
  3. Is Cub Cadet 2500 Series Worth the Money?
    By MelLandry in forum Cub Cadet L&G
    Last Post: 08-30-2009, 09:53 PM
  4. Log Splitter Pump Question
    By robmunach in forum Hydraulics
    Last Post: 04-29-2009, 10:18 AM
  5. Heat pump/ furnace question
    By Code54 in forum Rural Living
    Last Post: 12-04-2005, 12:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
